Re: G-Raider 3.0L Supercharger Project
[Re: fasteddy]
#726801
02/19/10 07:06 AM
That looks very nice Frank!
 Karma's Law - For every action there is a multiplied reaction! 93 Pajero GLS 3.0 V6 LWB - SOLD 2001 Gen3 Di-D LWB - SOLD 2005 Touareg R5 2.5 TDi
[Re: FrankR]
#726802
02/19/10 07:32 AM
All I can say is "wow"... <img src="/forums/images/graemlins/kewl.gif" alt="" />
73 -Jon KJ6GVM As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter Grampa's Trooper 1974 FJ40 1987 FJ60
[Re: fasteddy]
#726803
02/19/10 04:42 PM
Has it got 10v left on it? You can fix it with epsom salts if it does... I think his Concord is sealed completely. Don't think that will work???
[Re: hazy_daze]
#726804
02/19/10 05:42 PM
No, that won't work - it's a sealed AGM battery.
I did find some corrosion between the posts and adapter clamps and I can now read 5.75v. I doubt it's recoverable, but I'm going to make one last attempt to desulphate it with cleaner connections.
Frank
[Re: FrankR]
#726805
02/20/10 12:08 AM
<img src="/forums/images/graemlins/mrt.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> loving it!
88 Dodge Raider 1.5" lift 32"X11.5" A/T tires 15X10 vintage enkei's
[Re: FrankR]
#726806
02/20/10 07:00 AM
Just giving you (not deserved) [email]cr@p[/email], Frank, but this is being held up over a battery? I'd bet there's guys on here that would be happy to pedal a stationary bike hooked to a generator to get 13.6v for ya.
Looking forward to the (positive, in more ways than one) outcome.
[Re: JohnnyBfromPeoria]
#726807
02/20/10 08:09 AM
AGM revival huh?
From shoulder height drop it on its terminals into some dirt (so as not to break the posts through the top) then try to charge. This method revived a optima red top AGM for me once got another 3 years out of it for PA_JERO.
There is a site with a bunch of ways to bring them back, but thats all the way on the internet somewhere. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: TOASTY]
#726808
02/20/10 12:25 PM
It does sound silly to hold this up while I tinker with a battery. <img src="/forums/images/graemlins/lol.gif" alt="" /> I'm making some progress recovering it, but it's probably not going to be a reliable fix. I just looked to see when I bought the battery and it was in December '04. Since then, it has been abused by sitting for long periods without charging, so it's time for a new one.
So, now I'll hold it up while I wait for one to be shipped. <img src="/forums/images/graemlins/lol.gif" alt="" />
Frank
[Re: FrankR]
#726809
02/20/10 12:42 PM
Nothing wrong with tinkering <img src="/forums/images/graemlins/kewl.gif" alt="" />
That engine looks really lovely, as usual <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: Mad_Scientist]
#726810
02/21/10 09:30 PM
I brought a reclaimed battery home from the yard and stuck it in temporarily to move this along a little...... pumped out the year-old gas and put in 5 fresh gallons of 93...... primed the oil pump, connected the injectors and...... IT's ALIVE! There is nothing that sounds so good as a fresh engine firing off for the first time. This one sounds like it might be a good one after I sort through a surging at idle and a light popping in the exhaust I can hear at 2000rpm...... I think it might be the o2 sensor that needs calibrating - it's been sitting a year and I forgot to calibrate it before I started the engine. I got 80+ psi oil pressure on startup..... have over 20 psi at idle and 45psi at 2000rpm.... the oil pump relief valve appears to be working properly....... no fluid leaks. <img src="/forums/images/graemlins/kewl.gif" alt="" /> The sound and picture quality of this phone is terrible, but here are clips near the end of the 2000rpm 20 minute test run in the garage: Video 1 Video 2 Video 3Up close and personal, it sounds lovely. <img src="/forums/images/graemlins/evil.gif" alt="" /> Now I need to drain and refill the fluids, change the oil filter, put on some tires and go for a break-in drive. Frank
