Re: Opinion on How to install Hi-Lift (A or B?)
[Re: J94_4runner]
#727162
06/06/06 08:17 AM
a buddy of mine had a GENIUS idea. he's working on his right now. in rear... cuting out the floor and basically sinking the spare tire. like a lot of cars have in the cargo area. Supras are like that. it's a sunken tire well with a fake floor over it. so i'm gonna look into fab'n that up. and I have a 3" BL so that might help things out quite a bit. Keep in mind your 35 will probably barely fit between the frame rails. Also if it is flush with the floor, it may hang down quite a bit. Take a tape outside and see.
[color:"darkgreen"]1986 4Runner - 4" IFS - 63" Chevys - 33" ATs - 5.29s - Rear Detroit Sliders - Kayline - Rebuilt 22RE - On Board Air AND Factory AC www.xtremefabricator.com[/color]
[Re: TheBandit]
#727163
06/06/06 01:41 PM
Toyota Section Staffer
Your false floor will be 9-10" above the current one. But you can pick up some storage around the tire beneath the false floor... Be advised you don't want to contact the frame crossmember with your tire well without isolating it somehow, unless you like buzzes and such. Also, the stock tiedowns are not sufficient for holding a tire - take them to the frame (again, rubber/urethane isolation from the body is recommended).
-Bill '87 4Runner w/ '96 5VZ-FE, 'Red Chili II' '97 Taco XtraCab 3RZ-FE, 'BlackBean' TLCA # 13257, Rising Sun 4x4 Club Land Use Coordinator "He who stops being better stops being good." -Oliver Cromwell
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5958 MB (Peak: 0.6441 MB) Data Comp: Off Server Time: 2026-06-15 10:33:34 UTCValid HTML 5 and Valid CSS
