Throttle Pos. Sensor adjustment #727394 05/27/06 05:32 PM
Jickle Offline OP
I just checked my TPS sensor and it was out of adjustment. It was reading infinity at idle, which it should read <2.3 k ohm I got that adjusted and also noticed there is a dead spot when you rotate the throttle from closed to wide open throttle. It's only one small spot near the wide open throttle. (around 3.5k ohm)
Should I worry about this, what happens when there is a dead spot on the TPS ?? thanks
stock 92 pickup, v6, xtra cab, 4x4 IFS, 204k miles
Re: Throttle Pos. Sensor adjustment [Re: Jickle] #727395 05/27/06 05:46 PM
4Crawler Offline
It might cause an error code to be set or a flat spot in the throttle response:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml#Troubleshooting
Or it may cause no problems. If you don't notice anything, run it as is. If it does cause problems, try cleaning it internally or replace it
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.5869 MB (Peak: 0.6349 MB) Data Comp: Off Server Time: 2026-11-13 08:36:04 UTC
