alternator problem? #727727 05/29/06 09:57 PM
Digital_Aardvark Offline OP
I just got my truck all back together, and it finally runs after 2 months. However, I've got a bit of a problem. With everything off, there is a draw from the battery of about 8amps. With it running, its about 15 volts at idle and 17-18 revved a bit. When I take the cable off the alternator (engine off) the draw from the battery goes away, regardless of whether the plug in the back is connected or not. Is my alternator/ regulator toast? It was working fine before I did the frame swap/SAS. Any ideas appreciated.
1989 3.0 5 spd extended cab with more rust than should be legally aloud, soon to have a D44 front and D60 rear
Re: alternator problem? [Re: Digital_Aardvark] #727728 05/29/06 11:32 PM
DirtCheap Offline
Check the regulator, could also be a bad diode leaking to ground which will kill draw current and kill the battery. Looks like possibly time to rebuild or replace the alt.
1989 Toyota SR5 DLX SB
1995 Toy DX XTRA Cab 4x4
1989 Dodge Raider 3.0 V6, 5 spd, Michelin LTX series, bouncey seat
1988 Dodge Raider A/T w/Offroad Package
1959 Corvette
1977 Z28
1979 Honda CBX 1000 6 cyl
Re: alternator problem? [Re: Digital_Aardvark] #727729 05/30/06 03:23 AM
Your alternator should be charging at 13-14.5 volts reguardless of engine speed. If the regulator is bad it will increase when the engine revs.
You should get it fixed very soon or you will toast your battery.
PHP: 7.4.33 Page Time: 2.423s Queries: 15 (0.005s) Memory: 0.5924 MB (Peak: 0.6473 MB) Data Comp: Off Server Time: 2026-11-15 07:14:41 UTC
