Quick flywheel measurement needed please #728569 06/02/06 06:03 PM
A
Andy87 Offline OP
Long story short: I'm putting a JDM Toyota diesel into my '92. I had to get a flywheel from Australia. Everything I've read and heard, from very reliable sources, confirms that any standard 22r(e) clutch kit will work with the flywheel I got. Problem is, I've gotten two different clutch kits from my local Napa and neither pressure plate fits my flywheel. One was too large, the other too small. Each time, the holes in the pressure plate ALMOST lined up with the dowels in the flywheel, but were off by maybe 1/8" or so.
If anyone has a 22r flywheel sitting around, can you do me a huge favor and measure the center-to-center distance between any of the three dowel pins on the flywheel? Mine measure out at about 9.25".
Thanks.
'87 Xtra Cab, 4wd, 22r, 5spd
'92 Xtra Cab, 4wd, 2L-TE diesel swap, 5spd
http://toyotadiesel.com/forums/showthread.php?t=2502
Re: Quick flywheel measurement needed please [Re: Andy87] #728570 06/02/06 08:23 PM
Jeffstoyo Offline
I just measured one of mine and it is 9" center to center. You may not have the correct flywheel. Mine is off of an 88 4Runner. I got my clutch from Schuck's this last time. I have purchased them from Napa in the past too. HTH
Jeff
It's all good!
83 Shortbed stepside lots of mods
82 Shortbed fully restored
85 Shortbed daily driver
88 4-runner-Wife's daily driver
Re: Quick flywheel measurement needed please [Re: Jeffstoyo] #728571 06/02/06 09:18 PM
A
Andy87 Offline OP
Crap... I thought that might be the case. The holes in the pressure plate I have right now are just about 9" center to center as well.
I really appreciate the help, thanks.
Re: Quick flywheel measurement needed please [Re: Andy87] #728572 06/02/06 10:03 PM
Staceman Offline
Will a 22r - re flywheel bolt up to the crank???
Re: Quick flywheel measurement needed please [Re: Staceman] #728573 06/02/06 10:45 PM
A
Andy87 Offline OP
It needs eight bolts, unfortunately. But aside from that, the diesel flywheel weighs ~50 lbs, so the driveability might suffer if I stuck a 25 or 30 pounder on there.
Re: Quick flywheel measurement needed please [Re: Andy87] #728574 06/03/06 12:07 AM
CJM Offline
[Linked Image] [Linked Image]
22r flywheel vrs ~ "L" diesel flywheel
22r# diesel
25lbs 37 lbs.
11" dia. 12" Dia
6 on 2 1/2" bolt pat. 6 on 2 3/4"
7/16" dia mount holes aprox 1/2"
1 3/4" aprox. height 2 1/4 "
I know its not what you asked ... but i thought it might help .
83 Trekker SR5
NEW Trekker forum
Re: Quick flywheel measurement needed please [Re: CJM] #728575 06/03/06 12:44 AM
A
Andy87 Offline OP
Hey, those are some good photos... never seen those ones before.
But, around the late 80s they came out with a revised version of the L diesel (actually the 2L diesel) which is the 2LII. The 2LII diesel flywheels have 8 bolt holes. But, most of the 2LII diesels came with a screwy dual-mass flywheel, so most people upgrade to a 3L (next version) solid flywheel, which is what I thought I got from a guy in Oz, but now I'm starting to wonder. It did fit very well on the crank though.
Re: Quick flywheel measurement needed please [Re: Andy87] #728576 06/03/06 04:45 AM
new to forum
testing if i can reply
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6207 MB (Peak: 0.7199 MB) Data Comp: Off Server Time: 2026-06-15 13:04:56 UTC
