Transmission Problems!
#728816
06/04/06 05:21 AM
Ive had my jeep about 2-3 months now, and it has performed flawlessly! Until today that is...
Second Gear has taken it upon its self to randomly pop out of gear at any time...
WHY is this? and what is the fix?
Re: Transmission Problems!
[Re: Macdaddy4738]
#728817
06/04/06 04:15 PM
It may help if you say what kind of Jeep and which type and model transmission you are talking about. <img src="/forums/images/graemlins/confused.gif" alt="" />
[Re: Macdaddy4738]
#728818
06/04/06 05:58 PM
Possibly worn engagement teeth?? Does it grind? Do you have body lift?
#728819
06/05/06 09:09 PM
its a 98 Jeep TJ, 5 speed transmission.
No body lift, no grinding, it just pops out, no real reason as to why.
[Re: Macdaddy4738]
#728820
06/06/06 04:25 AM
Unless there is something hitting the shifter, it's probably internal damage. Check out the shifter boot, ETC...
#728821
06/06/06 08:00 AM
yea i popped it off and everything, didnt see anything preventing it from staying in <img src="/forums/images/graemlins/scared.gif" alt="" />
[Re: Macdaddy4738]
#728822
06/06/06 04:14 PM
It's probably internal damage then... Try changing the fluid.
#728823
06/06/06 08:32 PM
Unless there is something hitting the shifter, it's probably internal damage. Check out the shifter boot, ETC... Taddaaa, it WAS the shiter boot. I popped it off, but put it back on. After I took it off and left it off, it worked fine <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6122 MB (Peak: 0.6924 MB) Data Comp: Off Server Time: 2026-07-13 09:18:57 UTCValid HTML 5 and Valid CSS
