Noises!! #728982 06/05/06 01:53 AM
racerfan120 Offline OP
Hi I have a 87' 4X4 Pickup and just recently drove it for the first time today. (Been working to make it drivable for the last month or two) Anyway when driving i noticed a very loud whine or grrrr noise, but this only happens when the clutch is let out. If you are simply sitting with the clutch pushed in then the noise is gone. I was thinking it was either the transfer case or a bearing in the transfer case, or a bearing in the transmission. It shifts just fine so its not the transmission itself. Any idea as to what it would be? Thanks for the replys a bunch!
Re: Noises!! [Re: racerfan120] #728983 06/05/06 02:48 AM
Rauch_Off_Road Offline
What about the clutch release bearing? I've had this on both w56 trannies I've had.
(aka suprathepeg, aka Sean)
Re: Noises!! [Re: Rauch_Off_Road] #728984 06/05/06 03:18 AM
Jeffstoyo Offline
Wouldn't the throw out bearing make the noise while the pedal is pushed in too? try putting the transfer case in neutral and see if the noise goes away.
Jeff
It's all good!
83 Shortbed stepside lots of mods
82 Shortbed fully restored
85 Shortbed daily driver
88 4-runner-Wife's daily driver
Re: Noises!! [Re: Jeffstoyo] #728985 06/05/06 03:26 AM
ya even in neutral on the 4wd it still makes the noise.
Re: Noises!! [Re: racerfan120] #728986 06/05/06 03:49 AM
1
1986xtracab Offline
input shaft bearing. i think
Re: Noises!! [Re: 1986xtracab] #728987 06/05/06 04:03 AM
The input shaft on the tranny or the transfer case?
Re: Noises!! [Re: racerfan120] #728988 06/05/06 04:32 AM
1
1986xtracab Offline
tranny
1986 xtra-cab 22re
stock everything
1991 bed
Re: Noises!! [Re: 1986xtracab] #728989 06/05/06 05:59 AM
2ndGenToyotaFan Offline
Yep, input shaft bearing (tranny).
Jerod
89 4Runner, 282k miles. "I gotta have more cow bell"
Re: Noises!! [Re: 2ndGenToyotaFan] #728990 06/06/06 04:41 AM
great thanks for the replys!
PHP: 7.4.33 Page Time: 2.337s Queries: 15 (0.004s) Memory: 0.6228 MB (Peak: 0.7089 MB) Data Comp: Off Server Time: 2026-06-17 07:16:10 UTC
