pulled a Code P 0306 #729150 06/05/06 09:28 PM
Rodeofox Offline OP
Went to AutoZone today to see what was causing the CEL light to be on. Their code reader said it was
P0306-- Misfire in the no 6 cylinder. So what to do now??
Alittle history on this 97 Rodeo. Just put 2 used, but cleaned and checked Heads on it. New Timing Belt, New spark plugs.
Could it be as simple as the hookup to the coil pack not working quite right? What are things to look for?
TIA
Re: pulled a Code P 0306 [Re: Rodeofox] #729151 06/05/06 09:51 PM
I?ll go for the hookup to the coil pack, check the simple thing, some cracks in the spark plug cable and the spark plug itself.
Re: pulled a Code P 0306 #729152 06/07/06 04:59 PM
Rodeofox Offline OP
Everything checks out okay. Could it be that the timing isnt perfect and thats whats causing the miss? I ask because the second time i did the timing belt due to a leaky water pump I recall not being able to get the drivers side cam to line up 100% with the timing notches?
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5896 MB (Peak: 0.6433 MB) Data Comp: Off Server Time: 2026-07-13 05:58:20 UTC
