Re: Birfield Eliminator Kit any good? [Re: XJCreeper] #729561 06/08/06 10:07 PM
CraShYota Offline
um thats why you get the 27 spline birfields from longfield....
but anyhow ur running 30" tires so youll be all set...
The other thing about longfields are that you can maximize your turning radius with no problems.
Welding and Fabrication Engineer
2003 taco V6 ext cab sr5
1988 Toyota Pickup V6(totaled)
Re: Birfield Eliminator Kit any good? [Re: XJCreeper] #729562 06/08/06 10:38 PM
G
Greg_Canada Offline
Prob 35's safely, 37's if youre easy on it.
For 40's, you need the 30's for sure... but then your ring gear becomes the weak spot...
89 4Runner
Re: Birfield Eliminator Kit any good? [Re: Greg_Canada] #729563 06/09/06 12:34 AM
XJCreeper Offline OP
Thanks guys for answering all my questions. Sounds like I'll be safe running the 31" tires with this is setup then. You guys are really making me wish I got the darned longfields. I should of thought about the future a little bit more <img src="/forums/images/graemlins/frown.gif" alt="" /> I just got them handed to me by the UPS guy so and my friend is coming over with some beer. Time to get big red rolling again! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Birfield Eliminator Kit any good? [Re: XJCreeper] #729564 06/09/06 03:40 AM
TheBandit Offline
If you decide on bigger tires and you really want to upgrade to Longs, just do it BEFORE you break the Marfields. You should be able to sell the Marfields to recoupe some of your money.
[color:"darkgreen"]1986 4Runner - 4" IFS - 63" Chevys - 33" ATs - 5.29s - Rear Detroit
Sliders - Kayline - Rebuilt 22RE - On Board Air AND Factory AC
www.xtremefabricator.com[/color]
Re: Birfield Eliminator Kit any good? [Re: Greg_Canada] #729565 06/09/06 03:54 AM
CraShYota Offline
Hub studs THEN driveshaft u-joints, THEN ring gear
Re: Birfield Eliminator Kit any good? [Re: CraShYota] #729566 06/09/06 04:37 AM
G
Greg_Canada Offline
hehhe i'm guessing you know from experience...
89 4Runner
Re: Birfield Eliminator Kit any good? [Re: XJCreeper] #729567 06/09/06 03:32 PM
Red_Chili Offline
Toyota Section Staffer
Now you tell me the marfields suck
Uh... I don't recall saying that. They don't. I just would not have ponied up for them if I could get Longfields. YMMV.
The folks were quite correct on Profields. They do indeed suck - or used to in the first run, at least. Ruined credibility in my book.
The Marfields may in fact work great in your application. Longfields suffer to a slight extent in that their hardness is reduced to gain strength in hard usage (at least the version I run are), which theoretically reduces their wear life.
My application requires strength even at some small expense of wear resistance.
-Bill
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6267 MB (Peak: 0.7171 MB) Data Comp: Off Server Time: 2026-10-22 02:14:32 UTC
