Rodeo stalling? #729587 06/07/06 10:40 PM
sfr4dr Offline OP
I have a 95 Rodeo 4x4 auto with 107k and as of a few days ago it has been stalling out on me. Usually it's just out of the blue. I'll be cruising at a constant speed and it just shuts down. Also if I rev it a little in park, as the engine revs down it will just go all the way and stall out. It still pulls strong and doesn't hesitate yet. What could this be?
Re: Rodeo stalling? [Re: sfr4dr] #729588 06/07/06 11:44 PM
bbusbee Offline
Fuel filter maybe? Does your check Engine light come on and have you checked for any trouble codes?
Re: Rodeo stalling? [Re: bbusbee] #729589 06/08/06 05:04 AM
sfr4dr Offline OP
The check engine light hasn't come on yet. The fuel filter is one that could cause that and not set off the check engine light. What else could cause this this and not throw a code?
1995 Rodeo V6 4WD
Re: Rodeo stalling? [Re: sfr4dr] #729590 06/08/06 08:11 PM
I had a problem with stalling after installing my hella's. I had a bad ground somewhere (seperated off the relay housing in the engine bay)
Check the exhaust also. I had a seperated S pipe and a disconnected muffler (must have run over something while wheeling smile
<img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Rodeo stalling? #729591 06/09/06 11:41 PM
sfr4dr Offline OP
Hmm. Those are random ones smile I do have driving lights on there but that would be odd for that to cause the stalling. Is there anything tricky to changing the fuel filter on the Rodeo? I've done them on other cars and it was easy.
1995 Rodeo V6 4WD
Re: Rodeo stalling? [Re: sfr4dr] #729592 06/12/06 05:53 PM
jsutton Offline
I have a Gen II Rodeo but changing the fuel filter was easy I'm sure its about the same on yours. Mine was located under the back door on the drivers side frame rail. I know my truck ran better after replacing the filter and putting in new plugs.
Re: Rodeo stalling? [Re: jsutton] #729593 06/12/06 11:00 PM
sfr4dr Offline OP
Well, I guess that's where I'll start. New plugs, fuel filter, and air filter would be good anyways.
1995 Rodeo V6 4WD
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6109 MB (Peak: 0.6887 MB) Data Comp: Off Server Time: 2026-06-20 01:56:46 UTC
