Should I cut a section off the timing belt cover? #730362 06/11/06 09:25 PM
bob large Offline OP
So IÆve been having problems with my 2.6 in my amigo. A bad sound thatÆs kind of like a really bad wheel bearing at 60mph. But it's coming from the engine. And it also has a bad idle. So long story short, IÆm pulling things apart looking for the problem. I thought it might have a bolt or something stuck somewhere behind one of the timing belt sprockets so I pulled all the belts and pulled the balancer, so that I could get the plastic lower timing belt cover off. And it was a pain.
So IÆm thinking I might cut the bottom of the cover off so that if I have to take the cover off again I wonÆt have to pull the balancer off.
I thought I would just cut a small section out, say about 4ö wide section, see pics.
So is this a good idea or a bad idea?
http://image52.webshots.com/52/7/23/17/470772317YHWojR_fs.jpg
http://community.webshots.com/photo/470771467/2186777840076401443vzoVTE
good idea?
single choice
Votes accepted starting: 06/11/06 05:00 AM
You must vote before you can view the results of this poll.
Steve C
Re: Should I cut a section off the timing belt cover? [Re: bob large] #730363 06/12/06 01:47 AM
JLEMOND Offline
WON,T REALLY HURT ANYTHING STEVE , EXCEPT THAT THE LOWER END OF THE BELT MAY GET INTO SOME SAND OR WTR , I HAVE SEEN THEM DONE THIS WAY A NO OF TIMES , ESP ON SOME OF THE RACE MTRS IN THE PICKUPS ,,JUST ANGLE YOUR CUT OVER AS CLOSE TO THE LOWEST MOUNTING BOLTS SO YOU WILL HAVE THE BOTTOM SUPPORTED JERRY
Re: Should I cut a section off the timing belt cover? [Re: JLEMOND] #730364 06/12/06 03:45 AM
9
94redrodeo Offline
I wouldn't do it my friend had a eagle talon and was out rallying and some mud got in a hole in the timing cover and broke the belt and bent the valves.
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
PHP: 7.4.33 Page Time: 0.006s Queries: 18 (0.004s) Memory: 0.6076 MB (Peak: 0.7099 MB) Data Comp: Off Server Time: 2026-05-30 12:32:11 UTC
