More 22R Carb Problems #730612 06/12/06 02:05 PM
Terrys_85_Toy Offline OP
Got an '84 4Runner with a 22R. Went to take it through emissions last week and it failed the CO (%). Should have been 1.20 or less, and it was around 2.2 for both high RPM and idle. The tech said it was running too rich.
Took it home and started playing around and found that, #1, I am getting hardly no vacuum at the distributer. #2, the PO has drilled out the plug for the mixture screw on the car. #3, I can't get the idle to drop below 1100 RPMs.
So, I check all the vacuum lines and replaced a few that looked bad, looked for other vacuum leaks (and found none). I reset the mixture screw based on the FSM (3 1/2 turns out) and tried to adjust the idle, but it still wouldn't go down. It would go up, but not down.
So now I'm stumped. Any suggestions?
Thanks
1985 Toyota Pickup
5.29's
Rear Spool
Dual Cases
35" BFG MTs
Re: More 22R Carb Problems [Re: Terrys_85_Toy] #730613 06/15/06 05:53 AM
ArbitraryNotion Offline
wish my webspace didn't go down.. I have a perfect pic...
Try turning down the cold idle screw. it hides in the linkage. Sometimes the cold idle screw will hang up the entire system and make it run at a higher idle all the time..
Also, did you check your AAP? (check FSM)
1986 Toyota 4x4 22wEBer
Ported EB Offroad H/O Head "Josh Cam"
Ported Intake & Weber38mm Carb
LCE Header & 2.25in Exhaust
RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
Re: More 22R Carb Problems [Re: Terrys_85_Toy] #730614 06/15/06 08:28 AM
Davepet Offline
Did that include checking all the vacuum diaphragms to see if any were blown?
Dave
PHP: 7.4.33 Page Time: 2.061s Queries: 15 (0.012s) Memory: 0.5930 MB (Peak: 0.6468 MB) Data Comp: Off Server Time: 2026-07-14 21:04:01 UTC
