pulling cylinder head #730751 06/13/06 01:20 AM
Are there any tricks or suggestions anyone has on pulling the head off? I need to swap a piston and rod out....any suggestions are welcome
Re: pulling cylinder head #730752 06/13/06 08:15 PM
Esquire812 Offline
Leave the intake manifold bolted to the head, just disconnect all vac, fuel and coolant lines before lifting. Will save you about an hours time and half a box of bandaids. Clearly label everything so you can reconnect electrical and lines correctly.
Take your time, slow may cost you an extra day....rushing may cost you alot more $$ and time waiting on replacement parts that were broke while rushing.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: pulling cylinder head [Re: Esquire812] #730753 06/14/06 02:38 AM
ok, thanks for the info...going to start this project on friday or sat...piston and rods are on their way <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: pulling cylinder head #730754 06/14/06 08:09 PM
Jeffstoyo Offline
Don't forget the bolt that goes from the front of the head down into the timing cover. It is burried in oil and located just below the distributor drive on the front of the cam. It is a 12mm head bolt. Most people don't know about this and can easily cause a big headache.
Jeff
It's all good!
83 Shortbed stepside lots of mods
82 Shortbed fully restored
85 Shortbed daily driver
88 4-runner-Wife's daily driver
Re: pulling cylinder head [Re: Jeffstoyo] #730755 06/17/06 02:14 AM
WOW!!!!! 24 years of burnt oil and oil sludge is truly an awe inspiring sight.....good thing i have a parts cleaner at work...head will be off tomorrow, all that's left is the intake side and that hidden bolt on the front of the head
Re: pulling cylinder head #730756 06/17/06 03:58 AM
Jeffstoyo Offline
Make sure you get a tap and clean the headbolt threads real good before reassembly, some of them will be pretty sludged up.
Jeff
It's all good!
Re: pulling cylinder head [Re: Jeffstoyo] #730757 06/17/06 05:11 AM
ok...what bolt size/thread count? All i have left to do tomorrow it get the timing chain off and the intake manifold, with that said is there any need to remove the carb when or before it comes off???
Re: pulling cylinder head #730758 06/17/06 09:49 PM
head's off, piston's out...and now i'm waiting on parts
Re: pulling cylinder head #730759 06/18/06 12:06 AM
Jeffstoyo Offline
The head bolts are 12mm x1.25mm pitch. I had to search a little to find one.
Jeff S.
It's all good!
Re: pulling cylinder head #730760 06/18/06 11:23 AM
motor_head27606 Offline
Why are you taking the TC cover off if you're only replacing a piston and rod ? Also, you don't need to remove the intake, just the exhaust manifold. I just replaced a #2 piston with a cracked skirt and it's not necessary to remove the cover, unless you're replacing the chain or guides, of course. Use q-tips to clean out the oil and grime from those head bolt holes. When assembling, only torque that little top front head bolt to 8-10ftlbs.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6264 MB (Peak: 0.7318 MB) Data Comp: Off Server Time: 2026-06-23 10:11:07 UTC
