Re: Replacement spring sources? [Re: strawmyers] #730888 06/16/06 02:33 AM
Rodeo Clown Offline
With needing to get new springs anyway, have you considered going to something longer for better performance? 56" Chevys seem popular with the 'Yota crowd.
I got the 56" Chevy's on my rig and I'm very happy with them. I believe that is what RobG has on his too. <img src="/forums/images/graemlins/kewl.gif" alt="" />
1997 Isuzu Rodeo - Auto - 31" ATs
1995 Honda Passport - 1 tons - 39" Boggers
Re: Replacement spring sources? [Re: lttlbddy] #730889 06/16/06 04:13 AM
strawmyers Offline
Isuzu Moderator
I've been running those on the Amigo for a few years now. Excellent product <img src="/forums/images/graemlins/kewl.gif" alt="" />
Sean Strawmyer
Re: Replacement spring sources? [Re: Rodeo Clown] #730890 06/17/06 06:32 PM
sweater Offline OP
What's a source or application on those? Any rear leaf-spring 1/2ton Chevy? I'm not against a rework of my rear spring hangers, but a direct replacement would save me some work (as I'm currently welder-less and would have to rely on others). Also, I do not want to gain anything more than an inch or so, and I suspect that a direct replacement would get me back to my desired height, seeing as the rears are so incredibly beat up. They're hosed. They look like a sine wave if you look down 'em.
I'd also like to try and avoid paying the cost of an upgraded spring, I guess. But something with more of a warranty might help offset that consideration. I heard from Steve G that Alcan's are all sorts of warranteed for life. Seeing as I'd mostly likely swap these out again in a couple of years, that'd help defer that future cost.
- mike
Re: Replacement spring sources? [Re: sweater] #730891 06/17/06 08:47 PM
paulevans76 Offline
rear springs from 80's toyota pickups/4runners are within about a half inch of centerpin placement and are about the same overall length. i've read that an isuzu leaf used on a toyota provides about 3" of lift, so maybe a 3" lift toyota spring would work for you.
now, most aftermarket toyota rear lift springs are longer, but I'm sure somebody makes a stock length rear lift spring. It would probably have more thin leaves, military wrap, etc which would work better than the stock packs (consisting of a few thick leaves and no mil wrap).
i'd call marlin, all-pro, trail-gear, etc. and let them know what you are looking for, and I'm sure they could help you figure it out.
hope this helps a little and good luck.
88 Troop - Posing yard art
Re: Replacement spring sources? [Re: lttlbddy] #730892 06/19/06 08:52 PM
NATO308 Offline
If you were happy with the stock Rodeo springs you had, why not grab a set from a 96-97 Rodeo out of a wrecking yard? I installed a set from a 97 Rodeo on my 94 Amigo to give it a 3" lift. Picked up a set of like new springs locally for $75.
By the way, the second spring from the top in a first gen Amigo spring cluster fits perfect as a third spring when added to a 97 Rodeo rear spring cluster. This long extra spring gives EXCELLENT, stability, and height to an Amigo. Raised the rear of my 94 Amigo another inch, 4" after settling in.
'94, and '00 Amigos and '00, 01 Rodeos. Rodeo springs and aftermarket 'hard top on 94. Aisin hubs OME 919's on the 2000 Amigo. 2000 and 2001 Rodeos have OME 912's and Aisin. Smoother ride with the OME 919's???
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6156 MB (Peak: 0.6818 MB) Data Comp: Off Server Time: 2026-05-28 01:04:36 UTC
