stalling problem
#730893
06/13/06 07:15 PM
it seemed to start all of a sudden. i was slowing down for a traffic light and when i stepped on the clutch the dash lit up. i was fishing around to try and inspect everything and im 95%sure its the egr system. the truck runs fine above idle. any direction someone could point me in to attempt to fix this? i wanna take the egr off but my truck wont be exempt.
87 4runner 33" bfg mt's no lift. dubbed the marine by my frinds. dead as of august 14 2005. 84 ex cab p/u 33"a/t, 3" suspension+3"bodylift, thorley header and 2.25xhaust, downey midrange cam+rocker set, very milled head! NO RUST!
Re: stalling problem
[Re: lookmomnobrains]
#730894
06/13/06 07:57 PM
You can test the egr by applying vacuum to the port and see if the engine stalls while holding the rpms up enough to keep from stalling now. If it makes it worse, then the egr vavle is probably ok. Maybe test for vac. leaks by spraying starting fluid around the vac lines and carb, if the idle goes up, you have a leak in that area. You are referring to the 84, right? Jeff
It's all good! 83 Shortbed stepside lots of mods 82 Shortbed fully restored 85 Shortbed daily driver 88 4-runner-Wife's daily driver
[Re: Jeffstoyo]
#730895
06/13/06 08:03 PM
Also, try tapping on teh EGR valve at idle and see if it smooths out. If so, valve is sticking open. Clean or replace. Verify correct vacuum hose connections as well. FSM has hookup and test procedures.
[Re: 4Crawler]
#730896
06/13/06 10:28 PM
i tried tapping it but to no avail. i think the diafraghm(i killed that 1) might be ripped in the egr valve. how do i test it with a vacuum pump?
#730897
06/14/06 12:28 AM
If you have a guage on your pump, hook up the pump to the egr valve and apply vacuum, if the guage holds steady, the diagram is ok. Jeff
[Re: Jeffstoyo]
#730898
06/14/06 06:25 AM
well everything on the egr checked out ok as per the 85 fsm i downloaded a while back. next it appeared to be a fuel problem to me. so off came the stock carb and all the egr to make way for the redline weber 38 i dug out of storage. there was definetly a carb problem. i dont stall out now but have a crappy idle. i took a propane torch (not lit) and leaked gas out around the manifold and few remaining vacuum ports. i might have an air leak because in one particular spot the propane made the trucks idle smooth out some. this carb idled fine on the exact long block im running now. the only remaining piece is the intake manifold. anyone got an offenhauser they wanna part with? <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
