replacement clutch hose
#731614
06/16/06 04:55 AM
Im trying to find a replacement for the rubber clutch line on my 89 trooper. Id like to get a braided line but am having trouble finding them. Anyone have any ideas where to pick one up? thanks
Mike Hamari '89 Trooper
Re: replacement clutch hose
[Re: mhamari]
#731615
06/16/06 08:12 AM
1994 nissan 240sx rear brake hose is 8" long front brake hose is 23.5" both inverted flare female fittings m10x1.0mm $15 at partsamerica.com (advance autoparts, shucks , checker, kragen)
There's no real advantage with a stainless braided hose in this application. But if you feel like building it, you could buy some aeroquip braided teflon hose and m10x1.0mm ends. Or use any aftermarket front hose for toyotas (all use 2 female ends of the same size. (A braided isuzu line wont work as they use banjo fittings in the front and t-fitting in the rear.. )
CHRIS 98 Amigo, 92 Pup
[Re: mhamari]
#731616
06/16/06 08:20 AM
take a look at this thread
2.6 Trooper 2.0 Impulse Turbo
[Re: pucci]
#731617
06/18/06 02:06 AM
Hey thanks for the replies, Im going crazy trying to bleed the air so I figure Ill just change everything and start fresh.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5998 MB (Peak: 0.6553 MB) Data Comp: Off Server Time: 2026-06-23 15:44:40 UTCValid HTML 5 and Valid CSS
