A340F vs A340H transmissions #732344 06/20/06 09:12 PM
RatLabGuy Offline OP
One came w/ 22re, other 3vze.
Otehr than the bellhousing, are there major differences? If needed... would a complete A340H be a drop-in replacement for the A340F if you also changed T-cases with it?
'89 FSM says nothing about different gear ratios etc.
Question Reality.
Re: A340F vs A340H transmissions [Re: RatLabGuy] #732345 06/21/06 12:54 AM
DirtyHarry Offline
Toyota Moderator
They are not the same. The A340H shares fluid between the transfer case and transmission and the parking mechanism is in the transfer case, so it cannot be removed from the transmission. The above is not true of the A340F. They also have different shift characteristics. I think that the gear ratios are the same (2.7ish?) and they are both chain driven cases.
Re: A340F vs A340H transmissions [Re: DirtyHarry] #732346 06/21/06 02:36 AM
ldivinag Offline
biggest diff, for me, is that the 340f is that you can slap in a gear driven t-case and therefore, a marlin adapter and an extra box... <img src="/forums/images/graemlins/wink.gif" alt="" />
http://www.4x4wire.com/toyota/tech/autocrawler/
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: A340F vs A340H transmissions [Re: ldivinag] #732347 06/21/06 03:15 AM
DirtyHarry Offline
Toyota Moderator
Inchworm now makes dual case adapters for the A340H. I documented one of the first installs, should be in Dirt Trucks magazine in a few months (darn print lead times...).
Re: A340F vs A340H transmissions [Re: DirtyHarry] #732348 06/21/06 03:22 AM
But if you were to change both units at once, as a whole - would it not eliminate this problem? AKA change both tranny and T-case so they match?
Question Reality.
Re: A340F vs A340H transmissions [Re: RatLabGuy] #732349 06/21/06 05:07 AM
willzrunna96 Offline
yes and no...the F uses 3 solenids inside the the tranny as the H has 4 2 shift 1 o/d and 1 transfer position. you will need the ecu from them as they are computer controlled. F is way better all the way.
Re: A340F vs A340H transmissions [Re: willzrunna96] #732350 06/21/06 05:03 PM
Thanks, that clarifies it a bit.
Question Reality.
Re: A340F vs A340H transmissions [Re: DirtyHarry] #732351 06/21/06 06:17 PM
Jeff the marmot Offline
I don't know about the A340H, but the gear ratios for the A340F are:
First 2.804
Second 1.531
Third 1.000
Fourth 0.705
Reverse 2.393
That was from an old archived post at http://www.4x4wire.com/forums/showflat.php?Cat=&Board=UBB89&Number=256769 regarding 3rd gen 4Runners.
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
Re: A340F vs A340H transmissions [Re: Jeff the marmot] #732352 06/21/06 07:37 PM
The A340E/A340F/A340H 4-Speed Automatic Overdrive Transmission
This is Toyotas ECT (Electronically Controlled Transmission) automatic. It is used in both 22RE (4wd) models and in the 3VZ-E and 22R-TE (both 2wd and 4wd) 1st 2.804, 2nd 1.531, 3rd 1.000, 4th 0.705 Reverse: 2.393.
Info above is from this site:
http://www.off-road.com/toyota/tech/other/4_dts.html
Low Range in the A340H transfer case is 2.66: 1,,if I remember correctly.
Mike in AR
Re: A340F vs A340H transmissions #732353 06/21/06 08:57 PM
Low range in the transfer case used behind the A340F is 2.56:1.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6373 MB (Peak: 0.7619 MB) Data Comp: Off Server Time: 2026-11-14 06:58:32 UTC
