lift question #732831 06/22/06 06:04 PM
kingfoss Offline OP
i bought a teraflex 5" lift kit for my TJ and was wondering if i need to extend the control arms out like some other lifts say to do. Any help would be great.
2000 TJ 5" lift
33" BFG AT
Rear 4-link coming soon
Front hp dana 44 and frod 9" Rear coming sonn
Re: lift question [Re: kingfoss] #732832 06/22/06 06:33 PM
Mudlover27 Offline
Ok, I am not sure what rig you got, or year, but the fact that yore asking about control arms I assume you have TJ, with 5 inches of lift your going to need a few things,
1, if you haven't modi your rear drive shaft from a slip yoke to a CV yet your going to need to, anyhting over 3.5 inches will result in drive line vibrations. (those trans drop kits help but Cv and slip yoke eliminator is the way to go)
2. Adj upper and lower will alloww for better pinion angle as well as lengthen the wheel base back to its stock position with out them your going to notice your tires aren't going to be centered under the wheelwells.
3, get an adj pan head bars ( ie track bars for rear and front) if your kit dind't come with them)
I kow this is beyond what you asked for but, I wish some one told me all this when I lifted my jeep, so I didnt have do it all at different times
good luck
ML
98 wrangler 2.5l 3 inch rustys, 2 inch body, 33X12.5 MTR's DETROIT LOCKER, 4.88 gears, moser axles, Dana 44 (rubicon housing)
Re: lift question [Re: kingfoss] #732833 06/26/06 04:08 PM
Your lift should have come with the right length arms. Once it is installed the tires should look to be about the same spacing as before relative to the fenders, or maybe an inch or to closer to the middle of the jeep. If they look like the will rub the fenders closer to the middle of the jeep you need longer arms.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5894 MB (Peak: 0.6446 MB) Data Comp: Off Server Time: 2026-06-03 16:14:19 UTC
