problem with 99 amigo #732936 06/23/06 02:52 AM
madman95.5 Offline OP
Hello all,
I have a 99 3.2v6 auto that is having some driving problems. Yesterday on the way home it just stopped running and wouldn't start back up. It cranked but that was it, so i got it home and disconnected the battery. This morning I re-connected it and it started right up. I took it down the road and 6 miles down the road it quit again. I have replaced the fuel filter awhile ago and did the fuel guage fix. but the gas guage is acting up again after 6 months. I don't know if it is the fuel pump or something else. any help would be appreciated.
Adam 2003 chevy suburban 5.3 4x4
1989 chevy suburban 350 v-8 4x4 - superwinch hubs-(sold)
(sold) 95.5 Rodeo S 3.2 4x4 - K&N drop-in,2.5in lift, 31x10.50r15 wild country txr,superwinch manual hubs
Re: problem with 99 amigo [Re: madman95.5] #732937 06/24/06 09:30 AM
NATO308 Offline
Check the fuel line pressure at the fuel rail. A common and not to well discussed problem with just changing the sender is accidentally cutting the internal fuel line when reinstalling the pump.
Also check the fuel back pressure regulator by pulling the vacuum hose before starting when the engine is cool. If fuel shoots out the regulator, you have a problem.
Mike
'94, and '00 Amigos and '00, 01 Rodeos. Rodeo springs and aftermarket 'hard top on 94. Aisin hubs OME 919's on the 2000 Amigo. 2000 and 2001 Rodeos have OME 912's and Aisin. Smoother ride with the OME 919's???
Re: problem with 99 amigo [Re: NATO308] #732938 06/24/06 03:48 PM
strawmyers Offline
Isuzu Moderator
Also, next time it does it, get out and undo/reinstall the gas cap and see if it'll start. Sounds odd; but it seems to have helped others in the past IIRC.
Sean Strawmyer
PHP: 7.4.33 Page Time: 6.420s Queries: 15 (0.006s) Memory: 0.5930 MB (Peak: 0.6469 MB) Data Comp: Off Server Time: 2026-11-02 08:30:17 UTC
