Re: Droping oil pan on IFS 22RE?
[Re: Jeffstoyo]
#733277
06/30/06 03:28 PM
you got it easy! i did the crank, rods, bearings blahblah on my motor then saw metal in the oil agian! i pulled it apart figuing my new crank was shot and it was fine... i pulled it apart for no reason! then putting it back together a head bolt stripped @ 35ft lbs of torque... put a permasert (helicoil) in there then put the water bypass pipe under the intake on and it leaked so i was tighening it to get it to stop and the bolts just kept spinning <img src="/forums/images/graemlins/zombie.gif" alt="" /> i ended up drilling through the rear bolt and puttin another bolt through the whole thing with a nut on the end! cost me 2 days <img src="/forums/images/graemlins/angry.gif" alt="" /> <img src="/forums/images/graemlins/ignore.gif" alt="" />
i guess thats what i get for being careless while messin with this old stuff... <img src="/forums/images/graemlins/shame.gif" alt="" />
22RE OWNERS CHECK FOR DEBRIS IN YOUR OIL PANS! YOU MIGHT SAVE YOUR MOTOR!*** 1989 Toyota pickup 22re 5spd 4wd *** * New mods * - 305/70/R16 (33X12.5)
- 2 in suspention lift (zuk coils)
- minor body work
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5900 MB (Peak: 0.6291 MB) Data Comp: Off Server Time: 2026-06-17 08:03:17 UTCValid HTML 5 and Valid CSS
