idle knock? timing at 12+*??? #733696 06/27/06 02:54 AM
ToYPU Offline OP
1989 22re fresh motar.
Motor is idling high... but when i retard timing toward 5* with jumper installed it makes a knocking noise that sounds like it is comin from #4cyl. when i advance it to 12+* the knock goes away, motor idles a little higher but knock goes away... help!
thanks
kevin
22RE OWNERS CHECK FOR DEBRIS IN YOUR OIL PANS! YOU MIGHT SAVE YOUR MOTOR!
*** 1989 Toyota pickup 22re 5spd 4wd ***
* New mods *
  • 305/70/R16 (33X12.5)
  • 2 in suspention lift (zuk coils)
  • minor body work
Re: idle knock? timing at 12+*??? [Re: ToYPU] #733697 06/27/06 07:24 AM
kewlynx Offline
Are you sure the distributor was stabbed in at 0 TDC? Would be the place to start, assuming the TC chain was also properly installed.
Also make sure the TPS has been set back up properly.
**ubi apis- ibi salus**
Re: idle knock? timing at 12+*??? [Re: kewlynx] #733698 06/27/06 12:57 PM
ToYPU Offline OP
i thought my chilton said to stab it at 5*? <img src="/forums/images/graemlins/confused.gif" alt="" />
is there any way to check the timing chain 100% with out pulling the oil pump off? im pretty sure the vavle timing is right because i put the thing at TDC and made the TC sproket tilted slightly to the drivers side like it always was... is there a better method?
i have an aftermarket TC with no "bright links" so its tough...
kevin <img src="/forums/images/graemlins/confused.gif" alt="" />
* New mods *
  • minor body work
Re: idle knock? timing at 12+*??? [Re: ToYPU] #733699 06/27/06 02:45 PM
DRTDEVL Offline
Does the idle change when you install the jumper? If not, leave it at 12*BTDC, then go after your TPS.
Re: idle knock? timing at 12+*??? [Re: ToYPU] #733700 06/27/06 04:28 PM
Jeffstoyo Offline
The dot on the cam sprocket should be just to the left of the top (11:30 position). If you have to the right, then you need to pull the cam sprocket off and rotate it a tooth or two. You don't need the shiny link to set this up. Just make sure the crank is at TDC and the cam dowel is at TDC then install the cam sprocket at make sure the dimple on the sprocket is just before TDC.
Jeff
It's all good!
83 Shortbed stepside lots of mods
82 Shortbed fully restored
85 Shortbed daily driver
88 4-runner-Wife's daily driver
Re: idle knock? timing at 12+*??? [Re: Jeffstoyo] #733701 06/27/06 09:19 PM
ToYPU Offline OP
Jeff
will be changin that... its 1130 if you are lookin at the cam right? so the dimple is on the passenger side of the truck?
thanks!
kevin
* New mods *
  • minor body work
Re: idle knock? timing at 12+*??? [Re: ToYPU] #733702 06/27/06 09:39 PM
4Crawler Offline
Re: idle knock? timing at 12+*??? [Re: 4Crawler] #733703 06/28/06 01:19 PM
ToYPU Offline OP
thanks 4crawler but i have no "bright links" on my aftermarket chain and i would rather not have to pull the tc cover off again... wat are the chances of me getting it right if i set it to tdc and point that dimple at 1130-1145?
* New mods *
  • minor body work
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6229 MB (Peak: 0.7217 MB) Data Comp: Off Server Time: 2026-06-14 07:57:06 UTC
