deisel questions....not sure which one. ;)~ #733974 06/28/06 12:18 AM
Bansil Offline OP
Ok yes I searched but my hamster's wheel broke on page 4 <img src="/forums/images/graemlins/smile.gif" alt="" />
Lot's of questions in one spot may help others though <img src="/forums/images/graemlins/kewl.gif" alt="" />
Will a Isuzu turbo diesel be able to spin 33's off road with stock gearing?
How to know which diesel I'm looking at????
It has square headlights so post 88,basic 2dr....
not sure of trans yet will look tommorrow.
Can rebuild parts be found?How deep of a wallet is needed?
Can the fuel pump be rebuilt? hadda hadda?
Will said engine bolt up to a 5spd that was behind a 91 2,8 w/5spd?
How much of the factory harness will be needed?
And lastone right now,Where can the turbo be rebuilt at?
oops lied....... <img src="/forums/images/graemlins/smile.gif" alt="" />
Can basic diesel mods be done?like bigger turbo,fuel pressure increase etc?
just looking for ideas since the 3.4 died.
Thanks Doug
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: deisel questions....not sure which one. ;)~ [Re: Bansil] #733975 06/28/06 05:25 PM
turboDIESELtrooper Offline
Doug, I'd have to say most all of the Isuzu turbo diesel engines fitted originally in a truck or SUV will turn 33" tires in an off-road situation. Obviously the diesel engine will create the much more needed torque at a lower rpm (which you will no doubt be running at when going off road). To answer all your questions it kinda depends on what diesel engine you're looking at to go with. The only turbo diesel engine we saw here in the US was the C223-T in 86 and 87 for the Troopers. It can still be rebuilt with original parts, but from what I've heard and read it is not cheap to rebuild the engine (looking at at least $1,000). A good running C223-T probably will not equal up to the power of an equally good running GM 2.8 V6. If I had to guess I'd say you probably wouldn't like the switch if you did it. The V6 engine's 5-speed transmission will not be able to be used behind this turbo diesel engine. It requires its own diesel specific transmission, so it's best to get the diesel engine with trans as a package. The fuel injection pump and turbocharger can get rebuilt at any good diesel shop where they specialize in doing so. You will always have access to getting those two parts rebuilt as long as you own the vehicle. That is not the issue and usually costs at least $300 for injection pump to be rebuilt and probably almost the same or a little less for the turbocharger. If converting to diesel, the factory wiring harness would be a good idea to get to make it easier to finish. Now if you look at Isuzu turbo diesel engines outside of the US market, for instance the UK market, then you have an option of two other engines that may interest you. One is a 2.8 turbo diesel and the other is a 3.1 turbo diesel, both 4 cylinder engines that would likely take to modifying much better than the older 2.2 C223-T would. Bigger turbo and fuel pump upgrades would increase power and torque on those engines to a reasonable level and still have reliability at the same time. The 2.8 was used in 87-91 Troopers and the 3.1 used in 92-97 (or 98) Troopers, all over in Great Britain. Aren't they lucky? A good site to learn more about them and talk with British owners is www.itocuk.co.uk Obviously you are going to be spending some money getting that kind of powerplant bought and delivered over here. There is always more info available here at the Diesels Forum too. Just do a search or get all threads viewed in the past year or two to learn much more. Hope I could be of help for you.
Salvy
Re: deisel questions....not sure which one. ;)~ [Re: turboDIESELtrooper] #733976 06/29/06 09:44 AM
Bansil Offline OP
Thanks for the answers.
Bansil
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: deisel questions....not sure which one. ;)~ [Re: Bansil] #733977 06/29/06 05:20 PM
Not a problem and glad I could help. Are you still considering the switch to a diesel engine?
Re: deisel questions....not sure which one. ;)~ [Re: Bansil] #733978 06/30/06 09:48 AM
Bansil Offline OP
probable not since those numbers don't sound real hot <img src="/forums/images/graemlins/smile.gif" alt="" />,but would like to have one some day.
Bansil
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
PHP: 7.4.33 Page Time: 1.742s Queries: 15 (0.005s) Memory: 0.6084 MB (Peak: 0.6914 MB) Data Comp: Off Server Time: 2026-06-17 06:25:51 UTC
