Re: Front Crank Seal
[Re: allochris]
#734011
07/19/06 08:10 PM
The speedy sleeve doesn't create too much interference with the seal? Cuz my pully is grooved, and I need to fix it.
[Re: atoyot]
#734012
07/19/06 10:38 PM
The speedy sleeve is very thin, works great. Just be careful installing. I gently tap around the ring with a small piece of wood carefully. Don't go pounding on it with a hammer <img src="/forums/images/graemlins/shame.gif" alt="" />
[Re: Staceman]
#734013
07/20/06 03:00 AM
Number of ways to fix this leak. A sleeve is one way. Ive had good results just seating the seal 3/4 of the way into the oil pump. Replace the oil pump and oil pump seal while you have this apart....no matter how you fix the main seal leak.
PS... I have like 5 front main seals laying around for 22R's. If you want one Ill send it to you for the price of shipping. I have these extra seals because a total rebuild kit that includes an oil pump also has another one in the gasket kit....and I have been known to rebuild a few 22R's.
Michael J. Carsner proud driver of "Aint Pretty"  37 boggers, 571 gears, Detroit+Lock-Rights, 20R stage 1 LC Engineering head on 22R motor. MUD!!! Its whats for dinner!!
[Re: atoyot]
#734014
07/20/06 09:47 PM
The speedy sleeve doesn't create too much interference with the seal? Cuz my pully is grooved, and I need to fix it. Can someone take a picture of the grooved section of the pulley? I have never seen one, so it'll be nice to know what it looks like when I'll take mine off.
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/ Camper/33x10.5BFG-AT/Open 4:88/1.5"BJS/ +2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
[Re: half_fast]
#734015
07/20/06 09:50 PM
Number of ways to fix this leak. A sleeve is one way. Ive had good results just seating the seal 3/4 of the way into the oil pump. Replace the oil pump and oil pump seal while you have this apart....no matter how you fix the main seal leak. Why do I have to replace oil pump? How do I know if I need a speedy sleeve? Does the sleeve go in btwn the oil pump & the front main seal, as a spacer thing?
[Re: allochris]
#734016
07/20/06 10:13 PM
He is referring to "Re-install" oil pump. It makes it easier to replace the seal if you work on the pump on the bench. You can replace the seal with the pump body still on the engine though. Jeff
It's all good! 83 Shortbed stepside lots of mods 82 Shortbed fully restored 85 Shortbed daily driver 88 4-runner-Wife's daily driver
[Re: kewlynx]
#734017
07/21/06 03:46 AM
Looks like the one in the rear; steel. Speedy sleeve is the one in the front. The rear one is the tool used to tap the sleeve on.
1994 4x4 22RE
[Re: FarmerTed]
#734018
07/22/06 12:46 AM
also you want to replace the oil pump o ring while your in there ,sometimes the o ring dries up and leaks around the oil pump to timing cover area.
[Re: FarmerTed]
#734019
07/22/06 05:27 AM
FarmerTed- are you sure you don't have that backwards? I've never used a Speedy-sleeve, but that front one looks way too thick to me. I would think that that much of an increase in the diameter of the pulley sealing surface would toast the seal from too much friction- seals a sensitive little buggers. Incidentally, does any one know the Napa part number for the SS? I'm gonna pick one up tommorrow. Maybe I'll just check the Napa website. I'll let you know what I find out...
[Re: atoyot]
#734020
07/22/06 05:38 AM
Screw that- the Napa website both sucks and blows. So does anyone have that part number?
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6344 MB (Peak: 0.7423 MB) Data Comp: Off Server Time: 2026-06-13 11:15:34 UTCValid HTML 5 and Valid CSS
