Front Crank Seal
#734001
06/28/06 03:42 AM
I got oil leaking from center of the front crank pully, on the back side. SO I guess it gotta be my crank pully front seal.
So should I get stock seal from dealer or just go to local store & get whatever brand available?
Anyone have done this also?
-Screw-driver to pry it out? -What size socket/round tube to press in, with hammer?
Thanks. <img src="/forums/images/graemlins/cheers.gif" alt="" />
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/ Camper/33x10.5BFG-AT/Open 4:88/1.5"BJS/ +2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: Front Crank Seal
[Re: allochris]
#734002
06/28/06 03:54 AM
Given our temp extremes up here I stick with the Yota seal; just my personal pref.
Crank bolt--19mm socket, rest breaker bar on driver's side frame. Remove coil plug. BUMP, do not start engine--
Crank pulley should simply wiggle off. This is also a good time to swap out belts if yours are lookin' a bit ratty. <img src="/forums/images/graemlins/kewl.gif" alt="" />
The oil that comes out from behind the seal is minimal; have a rag handy.
Inspect pulley. If there are any grooves, then you need a speedy-sleeve (NAPA). Put some RTV or loctite on the pulley, gently tap sleeve back on; I use a block of wood on top of the sleeve for this part.
Use a seal puller or S.D to remove seal; be VERY careful not to gouge the oil pump body, or you'll be out some moola for a new one. <img src="/forums/images/graemlins/shame.gif" alt="" />
Lightly grease new seal and tap back in; a socket works well if you don't have a sealer. Make sure it's fully seated.
Reinstall. Put truck in highest gear and set ebrake. Torque crank pulley bolt to 116 ft-lbs. (rent the wrench)
Finish putting stuff back together, tighten belts etc. Check oil level and fire up to check for leaks.
[Re: kewlynx]
#734003
06/28/06 04:02 AM
I use factory seals when I can, the parts store seals just don't last as long. JMTCW Jeff
It's all good! 83 Shortbed stepside lots of mods 82 Shortbed fully restored 85 Shortbed daily driver 88 4-runner-Wife's daily driver
[Re: Jeffstoyo]
#734004
06/28/06 04:16 AM
i usually have pretty good luck with parts store seals, national(NAPA/carquest) isn't a bad brand. timken seals for toyotas are generally an OEM seal, though...
'79 sport 4x4 longbed <img src="/forums/images/graemlins/smile.gif" alt="" /> 20/22R hybrid with EB's OS valves, 268c cam, offy intake, weber 32/36, thorley header, 5 speed swap, 34" LTBs, downey 3" springs, marlin hysteer, 4.88s and locked
'91 4x4 shortbed 22R-E, W56, the dd!
[Re: kyle-22r]
#734005
06/29/06 12:08 AM
Just brought a dealer one for $14.80cad + tax.
Anyway, what's a speedy-sleeve?
[Re: allochris]
#734006
06/29/06 02:07 AM
Looks like the one in the rear; steel. If your crankshaft neck is grooved or pitted, it won't help to just use a new seal; still gonna leak.
[Re: kewlynx]
#734007
07/18/06 05:07 PM
do I need to drain out oil b4 taking out the old front crank oil seal?
[Re: allochris]
#734008
07/18/06 05:24 PM
do I need to drain out oil b4 taking out the old front crank oil seal? No, you will have a little seepage of what's left in the pump, but that's about it.
[Re: Staceman]
#734009
07/19/06 12:47 AM
Really?
Does it mean that my 4cyl oil pan itself is deep enough to hold all the 4-5L of oil?
[Re: allochris]
#734010
07/19/06 02:47 PM
Look at the rear sump portion of the pan, and look at its relation to the pump. The pump sit's pretty high over the pan. The only oil you will lose is what's left in the pump when the crank pully is removed.
