Cable to electric speedo conversion?
#734394
06/29/06 01:26 PM
If i buy an electric speedo can i take the sender off the transfer case and put it on my transfercase in place of the cable one or are there other differences i am not considering?
is there any way to make a 6cyl tach work for a 4cyl motor?
(1989 22re pickup)
kevin
22RE OWNERS CHECK FOR DEBRIS IN YOUR OIL PANS! YOU MIGHT SAVE YOUR MOTOR!*** 1989 Toyota pickup 22re 5spd 4wd *** * New mods * - 305/70/R16 (33X12.5)
- 2 in suspention lift (zuk coils)
- minor body work
Re: Cable to electric speedo conversion?
[Re: ToYPU]
#734395
06/29/06 03:15 PM
If i buy an electric speedo can i take the sender off the transfer case and put it on my transfercase in place of the cable one or are there other differences i am not considering? Yep, should be a direct swap. is there any way to make a 6cyl tach work for a 4cyl motor?
(1989 22re pickup)
kevin Recalibrate it: http://www.mindspring.com/~jayk3/toyota/tachmod.htm
[Re: 4Crawler]
#734396
06/29/06 03:20 PM
you tha man! i knew i read somewhere i could recalibrate the 6... you prolly posted it somewhere lol
well that info just saved me 60.00 cause got my new SR5 cluster on ebay for 28.00!
thanks kevin <img src="/forums/images/graemlins/smile.gif" alt="" />
- minor body work
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5936 MB (Peak: 0.6475 MB) Data Comp: Off Server Time: 2026-06-12 04:34:46 UTCValid HTML 5 and Valid CSS
