Old man Emu vs Ironman is there a difference #734630 06/30/06 04:54 PM
Stephan_Botswana Offline OP
From the experience of you toughies out there I have a question.
Except for price is there a real difference between the two lift kits in performance?
Other good options.
What to do and not to do on a Rodeo when you do a suspension lift off the shelf?
Thanks
Maintenace is high but woth it.
Isuzu goes places!
Re: Old man Emu vs Ironman is there a difference [Re: Stephan_Botswana] #734631 06/30/06 05:54 PM
sweater Offline
Whoa - there are off-the-shelf lift kits for Rodeos? Why didn't I use one of those!?!
<img src="/forums/images/graemlins/smile.gif" alt="" />
Way back when, I actually did try to lift the Rodeo through a Calmini kit, then slowly whittled away at the $800 kit over the course of a year, finally settling on a solid axle swap.
What year is your Rodeo, by the way? There are some certain do's and don'ts, like "Don't try to go way too high and tear up all your CV boots like Mike did" and "Too little unsprung weight and HD torsion bars will make your kidneys bleed like Mike's do".
- mike
Re: Old man Emu vs Ironman is there a difference [Re: sweater] #734632 06/30/06 07:32 PM
Smiley Offline
Botswana Africa?
IÆm just guessing - but are you planning on getting your parts from the guys in the R.S.A.?
If so, they are truly a great bunch, and have thoroughly æfield-testedÆ <img src="/forums/images/graemlins/shiner.gif" alt="" /> all of the aftermarket components that they use on their Isuzus (mostly Troopers, Single-Cabs, and Double-Cabs).
If not - here are a few links for you:
http://www.isuzuoffroad.co.za/index.php
http://4xforum.co.za/cgi-bin/YaBB/YaBB.pl?board=Isuzu
A thread at IsuzuOffroad.co.za, featuring the supplier: Dune Offroad
^ (Dune sells Calmini products, and custom-fabricates a number of their own pieces as well)
Hope this helps <img src="/forums/images/graemlins/kewl.gif" alt="" />
Cheers! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Smiley <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 4.764s Queries: 15 (0.003s) Memory: 0.5942 MB (Peak: 0.6482 MB) Data Comp: Off Server Time: 2026-06-24 20:12:26 UTC
