1999 4runner coolant leak. possible headgasket?
#735355
07/04/06 05:39 PM
I have a 1999 4runner coolant leak. I get a little puddle on the driveway every morning. It's not coming from the radiator hoses. Could it be the headgasket?
Is there a recall on the headgasket for a 1999 4 runner? The 4runner has about 130k miles.
Re: 1999 4runner coolant leak. possible headgasket?
[Re: vrooooom]
#735356
07/05/06 06:52 PM
Is there a recall on the headgasket for a 1999 4 runner? The 4runner has about 130k miles. No there is no head gasket recall for 1999. The ended it in 1996. The leak you have is probably water pump if you still have original.
#735357
07/05/06 10:57 PM
The leak is coming from the back of the engine. Could it be the heater hoses?
[Re: vrooooom]
#735358
07/11/06 05:09 PM
Yes, it could be a heater hose or a small coolant line. The best way to check it is to pressure test the system. You'll probably be able to locate the leak this way.
FWIW, there has NEVER been a recall for the head gasket. Toyota had a Special Service Campaign (SSP V06) for head gaskets. This was a special warranty; recalls are for safety issues.
#735359
07/13/06 03:02 AM
HG recall was for the 3.0 and 14K of the first 3.4 engines.
I second the pressure check.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6014 MB (Peak: 0.6620 MB) Data Comp: Off Server Time: 2026-06-25 01:07:27 UTCValid HTML 5 and Valid CSS
