greasing the steering knuckles #735844 07/06/06 06:30 PM
krauthead Offline OP
In my manual it talks about greasing the steering knuckles. I says to remove two screws and grease and replace screws. I can't seem to find these. The upper ball joints have grease fittings. Are they talking about the lower ball joints when they say steerings knuckles? I do see a small hex bolt on the inside of the lower ball joint. I need a little help here.BTW '88 4wd pickup. <img src="/forums/images/graemlins/confused.gif" alt="" />
Hand me that crowbar.
Re: greasing the steering knuckles [Re: krauthead] #735845 07/06/06 06:36 PM
abnormaltoy Offline
I think if you read it again you'll find that it's the 85 and earlier that's being referenced.
I would rather suffer the consequences of a Conservative?s error, than suffer the consequences of a Socialist's intent.
Re: greasing the steering knuckles [Re: krauthead] #735846 07/06/06 06:41 PM
This info is from my '88 factory service manual. I didn't see anything in there about referencing '85 and earlier models.????
Re: greasing the steering knuckles [Re: krauthead] #735847 07/06/06 07:05 PM
abnormaltoy Offline
I could be talkin out my butt, it's been a long time since I've worked on IFS. I just checked my 88FSM and it does say that, but it points to the ball joints.
Re: greasing the steering knuckles [Re: krauthead] #735848 07/06/06 07:51 PM
Thanks for looking. Now you can see why I'm confused. I have changed every fluid on this truck and lubed every fitting but can't figure this one out. I'm just trying do thoroughly due all my maintainance. Anyone else out there who can comment on this.
Re: greasing the steering knuckles [Re: krauthead] #735849 07/06/06 08:01 PM
4Crawler Offline
Re: greasing the steering knuckles [Re: krauthead] #735850 07/06/06 08:11 PM
Thanks 4crawler, Can't say I saw anything definitive there. I wonder if they are just talking about the ball joints? I did read something about the bushings in the steering knuckles, but I don't see how those could be lubed after installed. At least I feel less stupid since you guys with more experience aren't sure either.
Re: greasing the steering knuckles [Re: krauthead] #735851 07/06/06 08:31 PM
abnormaltoy Offline
Well, speaking stictly for myself...I'm not exactly a fount of knowledge! I only know half of what I think I know!
Re: greasing the steering knuckles [Re: abnormaltoy] #735852 07/07/06 03:05 PM
Red_Chili Offline
Toyota Section Staffer
The IFS upper ball joints ship with a bolt in place of a zerk. Replace the bolt with an angled zerk and you will be good to go.
-Bill
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6266 MB (Peak: 0.7294 MB) Data Comp: Off Server Time: 2026-06-17 05:32:52 UTC
