Page 2 of 5 1 2 3 4 5
Re: My Build #736314 07/13/06 12:35 AM
Tikitgvr Offline OP
I already did that....I paid 4$ for 100lbs of blasting sand and I have a gun that hooks up to my air hose...so I am already set...
Re: My Build [Re: Tikitgvr] #736315 07/23/06 12:00 AM
Tikitgvr Offline OP
:twisted: IT HAS BEGUN :twisted:
This was at 940 am......
1 1/2 hours later....
After Lunch break......
And this is both projects that I am working on at the same time...
Re: My Build [Re: Tikitgvr] #736316 07/25/06 01:07 AM
Tikitgvr Offline OP
Got my bling bling today...Only took 2 damn weeks AFTER I paid for them to recieve them....
And yes I removed the for offroad use only sticker..
Re: My Build [Re: Tikitgvr] #736317 07/25/06 03:43 AM
That is a LOT of work.
Why'd you pull the engine?
Re: My Build #736318 07/25/06 11:32 AM
Tikitgvr Offline OP
It was shot....there was more oil on the outside than the inside...So he bought another engine and gave me the ho in the yj to use as a base for my stroker build for doing the swap for him...
Re: My Build [Re: Tikitgvr] #736319 07/30/06 11:13 PM
Tikitgvr Offline OP
Well pulled the axles today...about killed myself when I removed the rear axle the jeep fell but I was quick enough this time...found out my frame is twisted pretty badly, so I will be looking for a new frame before I proceed any further....
Re: My Build [Re: Tikitgvr] #736320 07/31/06 12:27 AM
That's some bad luck... You know how the frame twisted?
Those jack stand look scary <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: My Build #736321 07/31/06 02:10 AM
Tikitgvr Offline OP
yeah I bought it that way....I knew it had been wrecked because it had a rebuilt title...but damn I didnt know the frame was his bad.....oh well chit happens...I will just strip it and build from the ground up....
Re: My Build [Re: Tikitgvr] #736322 07/31/06 02:37 AM
ouch <img src="/forums/images/graemlins/mrt.gif" alt="" />
Re: My Build #736323 07/31/06 04:37 AM
DentedTacoma Offline
That is a lot of jack stands there.
98' Toyota Tacoma SR5
Manual Xtra Cab, Slight Lift
Maine Rules!
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6360 MB (Peak: 0.7561 MB) Data Comp: Off Server Time: 2026-11-02 02:02:59 UTC
