Page 5 of 5 1 2 3 4 5
Re: My Build [Re: Tikitgvr] #736344 08/26/06 05:21 PM
BigJim Offline
I would advise leaving the lectric one out of the jeep unless you plan on going under water... Then my advice would be to leave the stock one off of the install.
Both is redundunt as all get out.
Re: My Build [Re: Tikitgvr] #736345 08/26/06 05:27 PM
I got a bitchin electric fan that is 2070 CFM... I can drive my jeep at 1100 RPM up miller jeep trail in 80-90* weather and the thing never comes off the T-stat.
Here is what I did.
Re: My Build #736346 09/04/06 12:52 AM
Tikitgvr Offline OP
Well I got the motor and tranny in the frame..need to make my bracket to mount the tranny to the stock skid. I also got the spring perches tacked onto the 9" and the 44...I can almost set the body back on the frame now.....
Re: My Build [Re: Tikitgvr] #736347 03/05/07 12:38 AM
Tikitgvr Offline OP
Well got the jeep all put together today, only thing left now is to get the driveshafts, exhaust fixed, and brake lines. I need to mount my rear bumper and finish fabbing the front bumper that I started on today also.. Then I am going to bend my tcase shifters a bit to get them to function properly and I will be done...Hopefully next sunday I will be able to take it for a test run..
If I have enough time I am going to try to weld up some rock rails also...
My front bumper:
My welding skills are getting better:
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6022 MB (Peak: 0.6768 MB) Data Comp: Off Server Time: 2026-10-30 23:48:43 UTC
