22R hard to start/off idle bog????
#736378
07/09/06 05:58 PM
Recently my 86 22r 4x4 with 225k has developed a few problems. I dont kow if the issues are related or not. The truck is very hard to start after it has sat for 1 day. I have to pump the pedal 15 times and crank and crank. It used to be a 2 pump and it would light instantly. Also the high idle will stay on after you have come to a stop. If you tap the pedal the idle will return to normal. And finally the truck bogs horrible just off idle. If you tap the gas it caughs then revs, which makes it horrible starting from a stop. If you arent carefull the truck will stall. After that (upper RPM's) the truck runs great. I really dont know where to start because there are so many symtoms. If anyone has any ideas please let me know. Thanks Stinson
Re: 22R hard to start/off idle bog????
[Re: Stinson]
#736379
07/10/06 06:11 AM
have to pump the pedal 15 times the truck bogs horrible just off idle Both those symptoms can be caused by a faulty accelerator pump in the carb. With the air cleaner off & choke open, open the throttle a few times while looking down the carb. You should see a healthy stream of gas squirting into the throat. If not the pump is bad (assuming that your fuel level is correct in the sight window). Dave
[Re: Davepet]
#736380
07/10/06 09:35 PM
Thanks I will def check that. How much is an accelerator pump, and would I be able to get one at a parts store or is that a dealer only part? Thanks Stinson
[Re: Stinson]
#736381
07/10/06 11:17 PM
You will most likely have to purchase a carb. rebuild kit to get the acc. pump. Around $25-$35 for the kit. Jeff S.
It's all good! 83 Shortbed stepside lots of mods 82 Shortbed fully restored 85 Shortbed daily driver 88 4-runner-Wife's daily driver
[Re: Stinson]
#736382
07/11/06 01:29 AM
Recently my 86 22r 4x4 with 225k has developed a few problems. I dont kow if the issues are related or not. The truck is very hard to start after it has sat for 1 day. I have to pump the pedal 15 times and crank and crank. It used to be a 2 pump and it would light instantly. Also the high idle will stay on after you have come to a stop. If you tap the pedal the idle will return to normal. And finally the truck bogs horrible just off idle. If you tap the gas it caughs then revs, which makes it horrible starting from a stop. If you arent carefull the truck will stall. After that (upper RPM's) the truck runs great. I really dont know where to start because there are so many symtoms. If anyone has any ideas please let me know. Thanks Stinson I had a problem that was almost exactly like this. Eventually I couldn't get the truck to start at all and I burned a starter. After inspecting everything I could I started pulling ignition wires. When I pulled the lead wire that goes from the distributor to the ingnitor, the metal pieces crumbled into dust. Somehow it got fried. I replaced that one wire and all was good. Something simple you might check.
[Re: thxgoon]
#736383
07/13/06 09:34 PM
Well after a little more inpspection of the carb, I am getting a healthy stream of fuel from the acc pump. When the truck is running the fuel level is right in the middle of the sight glass. When I bump the throttle I do get a loud woshing sound from a little gismo mounted in the aircleaner housing. Not sure if that was there before or not. I am going to check the plug wires next, but it sure seems like a carb problem to me. ANy more ideas guys, Thanks Stinson
[Re: Stinson]
#736384
07/14/06 05:28 AM
My 84 FSM says under "Engine hesitates/poor acceleration: Carburator problems: Float level too low Accelerator pump faulty Power valve faulty Choke valve closed (hot engine) Choke system Fuel line clogged
The whooshing sound is most likely the air injection system doing it's thing.
Dave
[Re: Davepet]
#736385
07/19/06 04:04 PM
Davepet, thanks for the info.
I still have not gotten anywhere with this thing, I just cant seem to find anyhthing wrong. What the heck am I over looking? Thank Stinson
[Re: Stinson]
#736386
07/20/06 04:50 AM
If you've checked everything on that list, I'm out of ideas. My next step would probably be to rebuild the carb unless you've had it apart recently...
Dave
[Re: Stinson]
#736387
07/20/06 05:13 AM
You said the fuel was in the middle of the site glass while running, but you ALSO need to check it first thing in the AM to see if there's any fuel in view in the site glass at all BEFORE you fire 'er up.
If it's empty, the float/needle valve is shot. Your dipstick more than likely also smells like fuel. THIS is not good; will wash down your engine.
PHP: 7.4.33 Page Time: 0.102s Queries: 16 (0.022s) Memory: 0.6371 MB (Peak: 0.7616 MB) Data Comp: Off Server Time: 2026-11-16 20:58:33 UTCValid HTML 5 and Valid CSS
