scratches on cylinder wall
#736715
07/11/06 05:02 AM
My Montero SR 95 had the notorious smoke issue, like other owners do. After waiting for the traffic lights, I got bluish smoke. I suspected the valve seals. So, I took the heads out and got overhauled. Now, I noticed these scratches. Mechanics said my Montero won't crank after reinstallation. I had better get another engine. Do they look that serious? ![[Linked Image]](http://static.flickr.com/68/186982565_89296ba1d7_b.jpg)
Tats '95 Montero SR 3.5L DOHC
Re: scratches on cylinder wall
[Re: tats]
#736716
07/11/06 05:05 AM
i have seen worse.since it ran before i woul think that they screwed up on putting it back together.
[Re: tats]
#736717
07/11/06 05:26 AM
Notice the scratch that goes all the way to the top of the cylinder in your photo. That was caused by debris on top of the piston, not the rings which do not travel to the top of the cylinder.
It was dirt/debris that started your problem. If it were me, I would take some scotch brite and clean the cylinder in a sidways motion. This might get rid of 60% of your problems. What do you have to loose? Just head gasgets and some time. Good luck, I hope it turns out for the best.
[Re: Racer4]
#736718
07/11/06 05:43 AM
What quick responses! I love this place. Thank you, guys. Yes, it was running good before the overhaul, except the oil burn. BTW, I did not remove any pistons, only heads (yes, to do that, I had to remove lots). Worth to scotch brite a bit, reinstall the heads, and try?
[Re: tats]
#736719
07/11/06 06:22 AM
So you left the block as it was? And now the problem is it won't turn over? Wonder if the rings are sticking to the cylinder walls a little? Maybe a shot of oil down each might do the trick?
[Re: PHIL_]
#736720
07/11/06 06:33 AM
I have not yet done any. Still trying to find out if and how much I can get a new short block. Or, if there is any better way. I will post whatever I do.
[Re: tats]
#736721
07/11/06 07:10 AM
Run a finger nail across the scratches, if you just feel them then it's fine. If you nail catches then you can try a little scotch bright. It's not a show stopper but you will use a slight amount of oil.
Won't turn over ??? It ran when you brought it there?
[Re: tats]
#736722
07/11/06 03:37 PM
Mechanics said my Montero won't crank after reinstallation. The failure to crank is a "prediction" by his mechanic. I don't think the engine has been reassembled yet. I think the prediction is BS.
'90 Montero XLS (Sold, sadly) '95 Montero LS 160k '03 Montero Limited 30k
[Re: Winston]
#736723
07/11/06 05:39 PM
did you do the work o a shop?it is vey posible the timing belt is not set ight o thee is a wie not hooked up,or somthing like that.if it an before the heads came off then there is NO reason it should not run after.
[Re: tats]
#736724
07/11/06 06:27 PM
Has the engine ever overheated? Cylinder scoring like this can be the result of overheating (piston expansion). I think it will still smoke regardless of the heads, but I don't see why it wouldn't run.
'91 LWB, 31x10.5s, KYBs, A/T "I look like Robert De Niro, I drive a Mitsubishi Pajero" - Billy Bragg (not the original lyrics, but that's how he sang it when I saw him in Dublin in '04)
