flasher - turn signal - need help!! #736840 07/11/06 06:01 PM
barrfly Offline OP
My jeep (85 CJ7) is missing the flasher for the turn signal on the fuse panel. The hazard flasher is there. I bought a replacement part that matches the hazard flasher and plugged it into the turn signal slot, but it does not work, and seemes to not fit snuggly. Is the turn signal flasher different than the hazard flasher? The hazard flasher is a 552 - 12 V. Anyone know what the part name is for the turn signal? Where to buy one??
Re: flasher - turn signal - need help!! [Re: barrfly] #736841 07/25/06 05:32 PM
Thord Offline
Interesting, mine was the same way but I found another flasher wired up under the dash that contolled the turn signal. i got two flasher from walmart, model 552 last summer. they both seem to go out a couple weeks ago so i put in another yesterday. it worked. they must be cheap or i have a voltage problem. i assumed when the flasher wouldnt stay in my fuse box the previous owner wired it in somewhere, but i havent followed the wires to find out.
not sure if i helped, goodluck
86 CJ7, 258, MC2100 Carb, 4" Rough Country lift, 34" Swampers, Jeeperman bumper/tire carrier
Re: flasher - turn signal - need help!! [Re: Thord] #736842 07/26/06 06:12 AM
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.5894 MB (Peak: 0.6442 MB) Data Comp: Off Server Time: 2026-11-13 21:48:22 UTC
