moving to Arizona what to do for the treck?? #736983 07/12/06 07:09 AM
tweedclassic Offline OP
I own a 91 4runner with 120k on the clock. I am moving to Arizona in a month and wanted to know would be good preventative maintenance for the trip down and the change in environment (like 110 degrees during the day) so far I am going to do the usual oil change I thought I might put a cooler running thermostat in even though I have never had any overheating problems? oh yeah and i have a 22RE
Anything else?
thanks
91 4runner 22re 5spd
Re: moving to Arizona what to do for the treck?? [Re: tweedclassic] #736984 07/12/06 08:16 AM
Davepet Offline
If your coolent & hoses are in good shape & the radiator isn't stuffed with bugs, I'd say you're good to go. Changing to a cooler t-stat will just mean it be wide open a few degrees sooner in the hot weather. I'd keep it stock, *if* you have problems, you need radiator work, not a cooler t-stat.
Dave
Re: moving to Arizona what to do for the treck?? [Re: tweedclassic] #736985 07/12/06 01:11 PM
abnormaltoy Offline
Where in AZ are you moving?
Given your name, are you a guitar player?
Mark
I would rather suffer the consequences of a Conservative?s error, than suffer the consequences of a Socialist's intent.
Re: moving to Arizona what to do for the treck?? [Re: abnormaltoy] #736986 07/12/06 02:56 PM
Rodgertheshrubber Offline
MAKE SURE YOUR AC WORKS!!!!!!
"I am a shrubber, my name is Rodger the Shrubber. I arrange, design, and sell shrubberies"
Re: moving to Arizona what to do for the treck?? [Re: Rodgertheshrubber] #736987 07/12/06 04:30 PM
Staceman Offline
x2
My motor started running a little warm at 60MPH, A/C on full blast, in 114 degree heat.
I still had MUD packed in my 3 core radiator (fan side) from last March. Soak her down and clean her out, done!
Re: moving to Arizona what to do for the treck?? [Re: Staceman] #736988 07/12/06 04:40 PM
Seattlegti Offline
20W50 weight oil.Top off the trans and diffs, grease your u-joints and McGuires the hell out of the paint. Last but not least break your spare loose from under the truck. Believe me you'll need it.
I left Tucson a long time ago for the PNW. Haven't torn a tire open since.
Re: moving to Arizona what to do for the treck?? [Re: abnormaltoy] #736989 07/12/06 10:37 PM
yes i am a guitar player i am moving to phoenix AZ. no i havent had any over heating problems so i will just leave the t-stat for now i just changed the trans oil but have yet to do the diffs. yeah my A/c works but it could probabaly work better i will try and get it in top shape before the treck
Re: moving to Arizona what to do for the treck?? [Re: tweedclassic] #736990 07/13/06 02:50 AM
you will def want your ac in tip top shape. it dosn't cool down til the end of october. i have made the trip from ny to az several times in my toy. not really a big deal. change the oil right b4 you go. either change the belts and hoses or have some spares. maybe plugs, wires, cap and rotor. rear dif fluid and trans fluid if they have never been done. about all you can do.....
Re: moving to Arizona what to do for the treck?? [Re: tweedclassic] #736991 07/13/06 02:57 AM
kewlynx Offline
Read the anti-theft sticky in the Runner section. Yotas are targets.
Yep, another for the AC and the spare tire system check.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6259 MB (Peak: 0.7134 MB) Data Comp: Off Server Time: 2026-06-09 18:24:00 UTC
