3.0 ignition coil part number
#737052
07/12/06 08:54 PM
Hey guys,
Anyone know the part numbers for either the ignition coil or the whole assem. including the power transister?
I have had an issue with mine for some time and there is nothing in the bone yards around me. I finally gave up and started calling stealerships and they won't give me any info without having a VIN #, the truck is at home and by the time I get there the dealers are closed and I always forget to write the vin down and bring it to work with me...
John Pszenyczniak 67 Mustang Coupe 95 Firebird Formula 05 Ram hemi 4x4 91 Montero RS LWB w/ 320k miles before rebuild, 900 down and its still kicking!!!
Re: 3.0 ignition coil part number
[Re: johnpsz]
#737053
07/13/06 04:53 AM
I'm not sure, but it appears the '89 and '91 coils are the same according to RockAuto The FSM lists the '89 part # as MD131711 - but it appears to include the power transistor - and it should for $190 list/$145 discount price at Olympia I tried to use my Wincaps program to check, but can't get it to work for some reason. You should check with a dealer and find out what comes with the coil and then judge whether you want to try just a coil from an aftermarket supplier. I think you can get the power transistor separately from aftermarket folks as well... but the total for both in good quality might be close to OE at a discount. You also might call RockAuto and find out if their aftermarket units are coil only or if they include the power transistor.... very little info is available at-a-glance. Frank
[Re: FrankR]
#737054
07/13/06 02:26 PM
Mitsubishi used the same coil and igniter on other models. Look for other V6 6G72 engines in the junkyards.
