O.B.A. Question. Do I need a tank? #737129 07/13/06 05:10 AM
W
wyojeeper Offline OP
I'm in the process of gathering up the stuff to put onboard air in my YJ. My question is, Do I need a tank? Won't the compressor put out enough air to run my tools or air up my tires?
I'm using a York air conditioning compressor for a pump.
I already have a 3 gallon tank I could mount, but I want to see if it's necessary first.
Re: O.B.A. Question. Do I need a tank? [Re: wyojeeper] #737130 07/13/06 05:33 AM
Your going to want it as something to mount the pressure blow off and on/off switch as well as a buffer. The AC compressors are capable of 300 PSI or more, with just a line on it it will be hard to keep the pressure in a useable range. You can use some 3" pipe along the frame as a way to get a fitting to the rear and as a tank...
Re: O.B.A. Question. Do I need a tank? [Re: wyojeeper] #737131 07/13/06 06:31 AM
BigJim Offline
a great number of the ranchers down here in thorn country use a pipe bumper for a tank. I had not seen a pipe along the frame but that is an idea worth looking into also.
Re: O.B.A. Question. Do I need a tank? [Re: BigJim] #737132 07/13/06 06:46 AM
If it is ran with the frame it is protected from large boulders and such. If it is galvanized pipe, it should take a good beating...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5902 MB (Peak: 0.6495 MB) Data Comp: Off Server Time: 2026-06-13 12:58:52 UTC
