Re: Strange vibration. [Re: conner] #737520 07/24/06 10:02 PM
A
ATCGuy Offline OP
No change on removing the belts. My brother did comment on the engine moving when I switched into drive or reverse. I looked at it and noticed the same thing. However, I don't know if this is normal or not. It rolls to the passenger side when you shift into rev. or drive.
Heat shields appear tight, and skid plates where removed when I was last testing it, so it should not be them. The dipsticks at All Tune +Lube where the engine was installed say it's the rear diff vibrating; however they are not sure why the noise shows-up when revving in park.
Re: Strange vibration. [Re: ATCGuy] #737521 07/25/06 12:11 AM
monte3 Offline
It is sounding more like the motor mounts than anything else- esp. since the movement you described.
98 Gen 2.5
05 Pontiac GTO
91 Corvette ZR-1
2011 Kia Sorento (wifey mobile)
Clarkdale, AZ
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.004s) Memory: 0.5940 MB (Peak: 0.6428 MB) Data Comp: Off Server Time: 2026-05-26 04:51:27 UTC
