Help needed - Locked up transfer case
#737728
07/16/06 02:13 AM
I bought an 87 Samurai that ran and shifted perfectly. I put the trans in 2nd, and the transfer case in N per the owners' manual, and towed it 20 miles home. When I tried to drive it, I moved the lever from N to 4wd, and it stuck somewhere in between and won't be budged. The lever will not shift at all. The front driveshaft is turning but I'n unable to move forward or back. What now?
87 JX Zuke bone stock almost cherry 86 Heavy Chevy 350 one ton 26' RV
There's always time to do it over.
Re: Help needed - Locked up transfer case
[Re: tgzzzz]
#737729
07/24/06 07:24 PM
you'd probably have more luck getting an answer by posting this in the suzuki forum...
84x4 Toyota Ext. Cab Deluxe Not enough hours in the day to do what i want..... .....and sleep
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5854 MB (Peak: 0.6333 MB) Data Comp: Off Server Time: 2026-06-22 20:44:01 UTCValid HTML 5 and Valid CSS
