1990 Montero - Class III hitch? #737813 07/16/06 08:14 PM
dolomiti Offline OP
Has anyone had success finding/placing a Class III hitch on a Montero (specifically 1990). I want to load my motorcyle (370lbs wet) onto a 2" reciever mounted carrier such as this.
Is this too much for this vehicle (V6 - 5spd)?
Has anyone put a "universal" class III hitch on the montero?
Thanks
1998 Mitusbishi Montero (winter package)
1987 Land Rover One Ten
Re: 1990 Montero - Class III hitch? [Re: dolomiti] #737814 07/16/06 08:49 PM
LRJ4x4 Offline
I don't think you will find a universal class III, it's over the limit of the truck.
Your looking at 450 Lbs by the time you add everything up. Class III is rated at 600 lbs tongue weight. If your truck is in good shape you can get away with it. Do not fully load the truck ( people and gear ) and the cycle <img src="/forums/images/graemlins/shame.gif" alt="" />
I think you will have to go custom to get a class III installed with some extra reinforcement welding in.
Re: 1990 Montero - Class III hitch? [Re: LRJ4x4] #737815 07/17/06 12:05 AM
Let me go try to fing the maker tag on mine. It's frame mounted with a diagonal brace up to the frame crossmember hitch plate by the recovery loop. Very nice piece of goods...
Re: 1990 Montero - Class III hitch? [Re: fasteddy] #737816 07/17/06 04:52 AM
dolomiti Offline OP
did you have to drill holes to mount it?
Re: 1990 Montero - Class III hitch? [Re: dolomiti] #737817 07/18/06 12:43 AM
Came with the truck...
Re: 1990 Montero - Class III hitch? [Re: fasteddy] #737818 07/18/06 06:05 PM
dolomiti Offline OP
nobody else has tried to put a 2" reciever on your Montero?
Re: 1990 Montero - Class III hitch? [Re: dolomiti] #737819 07/18/06 07:11 PM
dolomiti Offline OP
Is there a difference between the 1992 and 1990? I found this but am unsure if it would work.
Re: 1990 Montero - Class III hitch? [Re: dolomiti] #737820 07/19/06 09:55 AM
FlaRaider Offline
I have one like this curt mfg
87 Raider - adopted by a new family
89 Raider - sole survivor
88 Montero - adopted by a new family
89 Montero - organ donor - R I P
90 Montero lwb - organ donor - R I P
Re: 1990 Montero - Class III hitch? [Re: dolomiti] #737821 07/19/06 03:28 PM
PHIL_ Offline
Nope, no diff. GenI and GenII hitches are the same. There are a few class IIIs available for the Montero. Here's the DrawTite (second one down) .
Here's the one I finally decided to get, Hidden Hitch 90324, since I will only be pulling a tent trailer, and I still have my pintle hitch for the really heavy stuff, if I ever need it. The price diff was also huge. Up here I paid $160 for the Hidden Hitch, and the frame mounted class III was over $300! If I could have chosen, I would've gotten the Curt Manuf classII, that NWTroop listed above. Its a little nicer than my HH, but I couldn't get it up here.
Phil
Re: 1990 Montero - Class III hitch? [Re: FlaRaider] #737822 07/20/06 03:34 AM
dolomiti Offline OP
thanks!
PHP: 7.4.33 Page Time: 0.019s Queries: 16 (0.014s) Memory: 0.6394 MB (Peak: 0.7635 MB) Data Comp: Off Server Time: 2026-11-14 23:03:14 UTC
