Replacing Front Brakes #738075 07/18/06 01:23 AM
DentedTacoma Offline OP
At some point I swore that I found something here on 4x4Wire about replacing front brake pads (mine is a 98 Tacoma). I searched to no avail. Can anyone point me in the right direction for finding a "tutorial" on replacing front brake pads?
98' Toyota Tacoma SR5
Manual Xtra Cab, Slight Lift
Maine Rules!
Re: Replacing Front Brakes [Re: DentedTacoma] #738076 07/18/06 03:39 AM
kewlynx Offline
You've got the front end maintenance section in the Toyota section above, and the FSM sticky'd here for your application.
**ubi apis- ibi salus**
Re: Replacing Front Brakes [Re: kewlynx] #738077 07/18/06 04:02 AM
Sorry but I dont see replacing the brake pads in the front end maintenance section and fail to see the sticky?
Maine Rules!
Re: Replacing Front Brakes [Re: DentedTacoma] #738078 07/18/06 05:45 AM
kewlynx Offline
The front end maintenance article gets you thru the hub stuff if you need it.
Sticky--SNAKE! Click on index to go to the Taco listings of posts and look for the red thumbpin. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Replacing Front Brakes [Re: DentedTacoma] #738079 07/18/06 12:44 PM
little_joe Offline
Former Admin
We have an article on brake work for a 4Runner, which should be identical for your vehicle.
4x4Wire's Toyota Section
1995 FZJ80 LandCruiser - 3 locking diffs, +200k mi, JD HIR's, 285/75R16 Nitto TG's
Olde North State Cruisers
Re: Replacing Front Brakes [Re: DentedTacoma] #738080 07/18/06 07:12 PM
Mark in AZ Offline
Toyota Moderator
Just did mine recently and it looks like the article joe posted is a good one <img src="/forums/images/graemlins/kewl.gif" alt="" />
Exploring in a T4R Ltd V8
Re: Replacing Front Brakes [Re: Mark in AZ] #738081 07/18/06 10:21 PM
Thanks for the help everyone.
Maine Rules!
Re: Replacing Front Brakes [Re: DentedTacoma] #738082 07/19/06 09:08 PM
So if anyone could answer within the next couple hours of daylight that would be great because I have both front wheels off and am ready to go and dont want to have to do it again. I am replacing my brakes and all is well except that the retainer pins will not come out. Should they slide out easy or is the fact that I am in the rust belt effecting them. I tried hitting them with a hammer but they wont budge, whats the deal here? Yes I did take out the pin that holds them in. Help please.
Maine Rules!
Re: Replacing Front Brakes [Re: DentedTacoma] #738083 07/19/06 09:29 PM
Mark in AZ Offline
Toyota Moderator
As you saw in the writeup, they're made to slide out so I'd say you're correct, they're rusted.
Re: Replacing Front Brakes [Re: Mark in AZ] #738084 07/19/06 11:17 PM
So what now? I sprayed a lot of blaster on them and might try again in a couple days, maybe wire brush the area and get what I can off. Any suggestions?
Maine Rules!
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.005s) Memory: 0.6347 MB (Peak: 0.7575 MB) Data Comp: Off Server Time: 2026-10-23 19:08:35 UTC
