Will This work with a tarus fan? #739717 07/24/06 01:37 AM
9
94redrodeo Offline OP
I am selling my red rodeo. Right now I turn the fan on manually. but I need it to be thermostaticallly controlled. I heard the tarus fan pulls 60 amps on the start and this is only thirty amp I can't find anything bigger. I am not looking to spend a lot of money since I'm getting rid of it. I just don't think the new owner will wan't or will remember to turn it on manually.
A MUCH SHORTER LINK
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
Re: Will This work with a tarus fan? [Re: 94redrodeo] #739718 07/24/06 02:37 AM
lttlbddy Offline
If your just looking for a bigger capacity relay, scroll to the bottom of this page:
70 amp Relay
This one says it request special connectors, I can't imagine what would be that special.
Just letting you know they are available.
Re: Will This work with a tarus fan? [Re: lttlbddy] #739719 07/24/06 04:13 AM
9
So if I use a 70 amp relay and a 60 amp fuse with this kit you think it will work okay
Re: Will This work with a tarus fan? [Re: 94redrodeo] #739720 07/25/06 04:06 PM
TeamPSI Offline
A Not So Horrendously Long LINK
Use that kit with a high amp relay.
1996 Rodeo 3.2l 4wd
3" Indy4x lift - 3" Body Lift - Calmini torsion bars - Superwinch hubs - Independent4x brake lines - 32x10.5x15 Pro Comp MT's - Flowmaster 2.5" cat-back - Indy4x Tie Rods - Rear Lockright
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.5988 MB (Peak: 0.6550 MB) Data Comp: Off Server Time: 2026-11-13 21:26:07 UTC
