Page 2 of 15 1 2 3 4 14 15
Re: Greek made locker for the KIA... [Re: georgek] #740303 10/13/06 03:44 PM
fokion Offline OP
update
Two sportages are already testing the diffs
The only info I have for the moment is that they were not wire activated as the previus ones but air-activated...
Re: Greek made locker for the KIA... [Re: fokion] #740304 10/13/06 05:26 PM
logansportage Offline
I'd love an air activated locker like an ARB!!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Please more details.
Re: Greek made locker for the KIA... [Re: fokion] #740305 10/16/06 09:01 AM
DamKia Offline
Kia Moderator
Fokion,
Do you have a internet link to the manufacturer, so others can have a look around the site, or at least express interest? I'm sure there are a few frustrated souls here...
Re: Greek made locker for the KIA... [Re: DamKia] #740306 10/16/06 10:04 AM
fokion Offline OP
Unfortunately no there is not any site, only posts in a Greek forum ( about 30 pages <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> in Greek <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />).
He had publiched some photow of the "final" product installed, that I will link shortly...
I have talked to the guy about this forum... so I will try to make him signup to speak with him directly...
Re: Greek made locker for the KIA... [Re: fokion] #740307 10/16/06 10:10 AM
fokion Offline OP
Air compressor were used to be the filter box
Rear diff assembled and ajusted ready for installation
Actuator
Front ( prototype ) diff
Re: Greek made locker for the KIA... [Re: fokion] #740308 10/16/06 10:30 AM
DamKia Offline
Kia Moderator
Looks good, noting that it is a 6 pinion design and not a 4 pinion as in the original. Should be nice and strong.
I dont think there should be any problems with the halfshaft spline strength you talked about earlier, as the punishment the Dave has metered out (on rocks) and the destruction of the diffs that I have done (general abuse, and "Damned Kia, how the f*** did that get up there?) have not affected the splines on the halfshafts.
The only technical issue you could bring to the attention of the manufacturer would be to replace the crush tube with a solid spacer and shims between the front and rear bearings on the (main) pinion. I would suggest that he looks at producing the spacer as a part of the upgrade, as the crush tubes can deform more than they should, allowing the pinion to "walk" up the ring, leading to misalignment and destrction of the ring/pinion (I believe this was a contributing factor in one of my "grenades")
Re: Greek made locker for the KIA... [Re: DamKia] #740309 10/16/06 10:49 AM
fokion Offline OP
Will forward your suggestions...
In any case the abuse that ARE taking the diffs is inkredible..
They are testing them even in 4WD at tight turns in dry tarmak <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> to see what will brake
Re: Greek made locker for the KIA... [Re: fokion] #740310 10/16/06 01:06 PM
Dave Scott Offline
this is all good to hear, been keeping an eye on this thread. seriously looks promising.
Re: Greek made locker for the KIA... [Re: Dave Scott] #740311 10/16/06 01:23 PM
fokion Offline OP
Its the closest I think we have ever got to a locker.... At least we can communicate <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
( To be on the safe side put all applicable disclaimers concerning this....)
Re: Greek made locker for the KIA... [Re: fokion] #740312 10/19/06 11:33 PM
I need to move to Greece. I got to have one of these!!!
The locker from Korea looked good, but if we can have one of these in the front AND either the LSD or air locker in the rear, sign me up.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6513 MB (Peak: 0.7617 MB) Data Comp: Off Server Time: 2026-06-23 06:08:19 UTC
