Page 2 of 3 1 2 3
Re: What should I do next with my 2.6 Amigo? [Re: bob large] #740728 07/31/06 03:02 AM
Jim_Paget Offline
Not sure why I never got a check engine light, or a low oil pressure light.
The check engine light only indicates an emissions-related problem. You could have zero oil pressure and it would not illuminate. Many people are under the misconception that the check engine light comes on with any problem with the engine. Not true.
As for the low oil pressure light, they typically come on at somewhere between 3 and 5 PSI. My dad fried a 335HP 390 once when an oil pump failed and the light didn't come on until it was too late.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: What should I do next with my 2.6 Amigo? [Re: bob large] #740729 07/31/06 04:04 AM
mlclark Offline
Isuzu Moderator
Bearings, lots of bearings. And, probably the journals that ride upon them. Good luck.
Steve, did you replace (or remember to install) the rubber gasket that goes around the top of the pickup tube where it goes into the block?
Michael
Re: What should I do next with my 2.6 Amigo? [Re: mlclark] #740730 07/31/06 11:25 AM
bob large Offline OP
yep i did.
as for the bearings, can you be more specific? am i looking at the head or bottom end?
Steve C
Re: What should I do next with my 2.6 Amigo? [Re: bob large] #740731 07/31/06 03:21 PM
mlclark Offline
Isuzu Moderator
There are no bearings in the top end, but you can wipe out cam journals and lobes. Depending upon the failure, maybe the head was starved first and you got away with it. As for the bottom end, we are talking crank and rod bearings. Possibly pins. It all depends and you won't know until you do a bit of tear down.
It will also depend upon the failure. Sudden or chronic (i.e., high enough to work, but not enough to really supply the engine, finally ending in complete failure). Either way, it is not pretty.
Good Luck,
Michael
Re: What should I do next with my 2.6 Amigo? [Re: mlclark] #740732 07/31/06 07:38 PM
JLEMOND Offline
STEVE MICHAEL IS RIGHT HERE , YOU NEED TO GO AHEAD AND PULL THE LOWER OIL PAN AN TAKE A LOOK , THE MAIN CRANKCASE OR OIL PAN AS IT IS CALLED ISN,T NECCESSARY , IT IS MUCH QUICKER THAN THE OIL PUMP ANYWAY, GET A GOOD LOOK AT THE OIL PMP PICKUP AND LOOK FOR PIECES OF BEARING MATERIEL, I AM WONDERING IF MAYBE YOU LOST THE THRUST BEARINGS AND THE GRINDING IS THE CRANKSHAFT IS MOVING FORWARD WHEN THE CLUTCH IS DEPRESSED, THIS WILL DEFINATELY HAVE AN EFFECT ON THE IDEL OF THE ENG IT WILL SLOW WAY DOWN AND ALL MOST STALL, LOWER PAN WOULD BE MY FIRST STEP IF YOU HAVENT ALLREADY CHEDCKED THIS FAR JERRY
Re: What should I do next with my 2.6 Amigo? [Re: JLEMOND] #740733 08/05/06 05:53 AM
Well, if I did major damage to the lower end of the engine, I guess I should have my other block rebuilt and start over.
I guess this time I will make sure the oil pump is working before I put it all together, and get an actual oil pressure gauge, instead of relying on the oil pressure light.
And it shouldnÆt take me near as long to put it all back together the second time around.
Just not sure if I should get a new head or reuse the one I have on it now.
Steve C
Re: What should I do next with my 2.6 Amigo? [Re: bob large] #740734 08/06/06 11:41 PM
Bucket Offline
Any of your rigs have working 4WD yet? Let's go wheelin' this fall, when it's cooler. Call TXCO Rig and see if he's still alive. You guys can talk engines, 'cause I think his is jacked up too. Trooper? Sammy? Amigo? Whichever one, makes no difference, the trails are calling your name... <img src="/forums/images/graemlins/zombie.gif" alt="" />
Bucket
'02 Trooper: OME 3inch lift, 33x10.5x15 BFG Muds on Black Rockcrawlers, ARB BullBar, Calmini T-bars, Indy4X HD Tie Rods and HD Rear Links, FDM sliders, Aisin hubs.
Re: What should I do next with my 2.6 Amigo? [Re: Bucket] #740735 08/08/06 02:18 AM
chasespeed Offline
Steve, is there an air conditionor on that thing?
And, not trying to call you out...but
Did you pop the hood, and verify where the noise was coming from, like with a mechanics stethoscope(screwdriver, peice of wood, etc)?
I am asking, becuase I have had problems in teh front accessories(pulies), bearing locking up, clutch in teh a/c compressor, etc, and caused me all kinda noises, and odd running.
Not touching the oil pump thing though, as I have yet to tear apart one of the isuzu 4 bangers.
But, usually, we prime the oil pump when an engine is re-assembled, and VERIFY it has pressure, before it is run for the first time...
Chase
Chase
Re: What should I do next with my 2.6 Amigo? [Re: chasespeed] #740736 08/09/06 03:01 AM
well i know it has to be the oil pump cuz i can't get any oil to come up into the head when i spin it.
Steve, as for wheeling; nope i don't have any rigs with 4x4. actulay i only have one rig thats running and it looks like it going to give up the ghost really soon. <img src="/forums/images/graemlins/frown.gif" alt="" />
Steve C
Re: What should I do next with my 2.6 Amigo? [Re: bob large] #740737 08/09/06 10:54 PM
Troopersphere Offline
I wonder... you still using Fram oil filters ? ? ?
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.004s) Memory: 0.6440 MB (Peak: 0.7496 MB) Data Comp: Off Server Time: 2026-06-20 20:13:35 UTC
