20R fuel injection?? anyone seen it???
#741200
07/29/06 06:57 PM
22R bottom end, 20R head....... guy wants fuel injection. can it be done at a reasonable cost?
Michael J. Carsner proud driver of "Aint Pretty"  37 boggers, 571 gears, Detroit+Lock-Rights, 20R stage 1 LC Engineering head on 22R motor. MUD!!! Its whats for dinner!!
Re: 20R fuel injection?? anyone seen it???
[Re: half_fast]
#741201
07/29/06 09:28 PM
Mike, It all depends on how much machine work the head/manifold or both will need to match the ports. The 20R intake is different than the 22R. If you can find a system similar to the Holley Projection, it would make it alot easier to adapt. Jeff
It's all good! 83 Shortbed stepside lots of mods 82 Shortbed fully restored 85 Shortbed daily driver 88 4-runner-Wife's daily driver
[Re: Jeffstoyo]
#741202
07/30/06 05:40 AM
You can adapt the 20r intake to take a holley 2bbl carb. You can adapt a holley 2bbl carb to Chevy TBI. I've used megasquirt to control TBI.. Basically did this on an early 22r motor. TBI is vastly superior to a carb, but really not as good as true port injection.
Other alternative would be to build a manifold for the 20r head.. Not as horribly difficult as you might think, but you need to be able to weld and do fabrication.
22REturbo.net 1988 4Runner 22RTE core, turbocharged, megasquirted...
[Re: dcg9381]
#741203
07/30/06 09:06 AM
So I can use a standard intake manifold and then mega-squirt as fuel injection? I thought you needed the volume of the plenum to get a correct mixture? Anyhow...Ive scanned the mega squirt website and Im confused about what needs to be purchased? suggestions?
Holly projection is out as even used ones cost $1000.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6003 MB (Peak: 0.6563 MB) Data Comp: Off Server Time: 2026-06-08 18:55:15 UTCValid HTML 5 and Valid CSS
