Page 5 of 5 1 2 3 4 5
Re: Installing a 3" SL [Re: m_a_b] #741676 08/08/06 11:42 AM
m_a_b Offline OP
by the way, I just realized that on the equations at the bottom, there should either be a square root over the whole left side, or the right side should be squared. I did the calculations right, I just didn't write down the equations right...
'99 Isuzu Amigo S, 3.2L 4x4 softtop, 3" Calmini Lift, Indy4x Custom Bumpers & Sliders
Re: Installing a 3" SL [Re: m_a_b] #741677 08/08/06 09:32 PM
Isuzukid Offline
They are quick to ship out another set to you, But the new set will be no help. You will run into the same problems like I did. ALL of their UCAs are a bit off. I had the same problem with my second set and just gave up. Sold them for $150 to salvage what I can, and left my stock UCA's on.
Re: Installing a 3" SL [Re: Isuzukid] #741678 08/09/06 12:06 PM
m_a_b Offline OP
Did you have this same problem, or were your UCA's out of dimension in another way?
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6014 MB (Peak: 0.6717 MB) Data Comp: Off Server Time: 2026-06-12 19:33:49 UTC
