What can you expect from a '95 LS
#741679
07/31/06 09:12 PM
Decided to pull my 2500lb tent trailer up to Donner Lake for a week of camping. Unfortunately, I ended up travelling on one of the hottest days of the year(Sat July 22). I was travelling from the East Bay, up I80 through Sacremento and up to Donner Lake. When I hit Rocklin the outside air temp gauge read 113F. <img src="/forums/images/graemlins/scared.gif" alt="" /> When I got to Donner the temp was still 92F.
In the end the Truck pulled like a champ. The coolant temperature gauge never budged. Not even a little bit. Oil pressure stayed nice and high (55-60psi). I really worked the engine to keep the truck up to speed. Was doing some 5000rpm pulls at 60mph. Saw quite a few vehicles pulled over (broken down).
I have owned the truck since nearly new, and have performed normal maint. (although I am not a maint freak). I drain and top up the coolant every other year. With the way that this truck (and my '90) have behaved (coolant temp wise) I dont understand the references to overheating and Auto Trans temperature problems. I use Mobil 1 (Dex III) in the tranny. Maybe that helps.
Just wanted to share. <img src="/forums/images/graemlins/cheers.gif" alt="" />
'90 Montero XLS (Sold, sadly) '95 Montero LS 160k '03 Montero Limited 30k
Re: What can you expect from a '95 LS
[Re: Winston]
#741680
07/31/06 11:03 PM
Thats a haul up to Donner Lake <img src="/forums/images/graemlins/patriot.gif" alt="" />
The cooling system is the key to a happy Mitsu <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: LRJ4x4]
#741681
08/03/06 05:43 AM
Donner lake is beutiful. My LS handles both 80 and 50 to Tahoe real well. Exactly what you said is what is true with mine as well. <img src="/forums/images/graemlins/cheers.gif" alt="" />
96 Montero LS 24V DOHC 3.0L. 98 Montero 24v SOHC 3.5L, factory rear locker, Winter/tow package. 63 Jaguar XKE 3.8L FHC 2000 Mercedes-Benz e430 07 fj cruiser
[Re: Winston]
#741682
08/03/06 10:52 AM
since you probably did the change to mobil 1 early on in the life of the trans, it probably didn't mess with anything. BUT if you ask brendan (87montero) he will tell you, don't use anything other than Diamond ATF from mitsu. Mobil 1 in a used worn trans will eat seals, and cause problems... <img src="/forums/images/graemlins/scared.gif" alt="" />
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6038 MB (Peak: 0.6606 MB) Data Comp: Off Server Time: 2026-11-14 09:04:36 UTCValid HTML 5 and Valid CSS
