change diff gears or transfer case gears
#742283
08/03/06 04:52 AM
I noticed that petroworks. com has a transfer case that changes the gear ratios as I would use with large tires (like 31"). I am used to changing the diff gears to acheive this. I assume that the torque on the drive train components will be harder using the t case gear set. Is it safe to do this? I am used to carrying spare axles, but would i also now need a spare drive train, etc?
Re: change diff gears or transfer case gears
#742284
08/03/06 05:56 AM
I carry a left and right front axle shaft in my spares box. If you carried an extra part for every upgrade, you wouldn't have room for the cooler (grin). I have both upgraded tcase gears and diff gears. Just do the math and figure which comes closer to what you need. I would not go overboard with one without doing the other.
Bill ---------------------------- God Forgives, Rocks Don't...
[Re: Billjohn]
#742285
08/03/06 06:10 PM
i have stock t case and 4.56 in the diffs turning 32" rubber and that is fine for now but i want the 4:1 t-case gears i say get both start with diff gears they are cheaper
if it don't fit, force it if it breaks, it needed to be replaced anyway
#742286
08/04/06 05:27 AM
Diff gears for now I say (and an ARB air locker). Anyways I had to rework the clutch and transmission. I should be done tomorrow.
Does anyone else rock left to right a good six inches at highway speed?
#742287
08/04/06 01:59 PM
Only when the wind gusts - or I'm getting passed by a Semi. It also happens when one runs shackles that are too long...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5956 MB (Peak: 0.6585 MB) Data Comp: Off Server Time: 2026-06-11 14:00:50 UTCValid HTML 5 and Valid CSS
