Got any Aussie Locker install tips? #742428 08/04/06 12:42 AM
Buck Offline OP
Just bought a Aussie Locker for the truck. Anybody have any tips for the install before I tear into it?
84 Ext. Cab Pickup.
Re: Got any Aussie Locker install tips? [Re: Buck] #742429 08/04/06 02:00 PM
go_big_blue Offline
I used this and this as references along with the supplied instructions. Take your time and keep everything clean.
1991 4wd Toyota 22re, 1.5" ball joint spacers, 1" body lift, 33 Baja Claws, Aussie locker, Budbuilt crossmember w/ 1" drivetrain lift
Re: Got any Aussie Locker install tips? [Re: go_big_blue] #742430 08/24/06 12:15 AM
Buck Offline OP
Started install the locker yesterday, jacked up, wheels off, driveshaft removed, diff drained. Today I yanked the axles out, pulled the diff. and installed the locker, I'll put it all back together tomorrow, here's a few pics.
My oh so organized workspace! <img src="/forums/images/graemlins/scared.gif" alt="" />
Can just see that the axles are popped out. Gonna have to replace the drivers side brake line, twisted a whole bunch while unbolting it, must be that 20 years of grime.
Here is the locker installed, just gotta put her all back together tomorrow.
Used Zuk's write up, Thanks Zuk!. Had to use a file to get things to fit inside, would of freaked if I hadn't read Zuk's writeup before starting.
84 Ext. Cab Pickup.
Re: Got any Aussie Locker install tips? [Re: Buck] #742431 08/24/06 03:32 AM
lethe Offline
i put my aussie locker in probably 5 months ago and it's been good so far. some times when you go around a corner and it suddenly engages it sounds like your rear end has exlpoded.
87' ext cab toy
Re: Got any Aussie Locker install tips? [Re: lethe] #742432 08/24/06 04:03 AM
ZUK Offline
good job, Buck <img src="/forums/images/graemlins/kewl.gif" alt="" />
mostly stock
Re: Got any Aussie Locker install tips? [Re: ZUK] #742433 08/24/06 07:58 PM
dcg9381 Offline
Don't forget to use the existing spacers (I forget the techinical name) when reinstalling..
22REturbo.net
1988 4Runner
Re: Got any Aussie Locker install tips? [Re: dcg9381] #742434 08/24/06 09:50 PM
Buck Offline OP
Thrust washers? yep, used em. Got it back together today and took it for a test drive. That first loud bang as I was backing out the driveway was a bit unnerving, but after things got all lubed up everything seems to work fine. Drove around a little bit with the windows down so I could hear the locker in action. I'll have to go out this weekend and play in the dirt. <img src="/forums/images/graemlins/kewl.gif" alt="" />
84 Ext. Cab Pickup.
Re: Got any Aussie Locker install tips? [Re: Buck] #742435 08/25/06 04:05 AM
Buck Offline OP
Well, couldn't wait for the weekend to test things out, so I went out this afternoon. Works Great! Made it up one short deeply rutted hill that I've never made it up before, always just sat there spinnin the tires. Also went up one long, steep hill that I've always made it up before with lots of negotiating, this time, straight up it, first try, no slippin or sliding at all! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Here's a couple pics of me and my daughter goofin around on a log.
84 Ext. Cab Pickup.
Re: Got any Aussie Locker install tips? [Re: Buck] #742436 08/25/06 12:49 PM
1
10_35lookoutbelow Offline
<img src="/forums/images/graemlins/smile.gif" alt="" /> Well Buck it sounds like that locker works pretty well! I've been looking at the Aussie pretty close for the last little while and pondering whether or not to get one. I still have stock open diffs. It seems like a pretty cheap mod that can help out alot!
How long would you say that it took to install?
My truck is my DD and in the winter I drive in snow most of the time, I've heard that installing an automatic locking device can give negative effects while driving in snow. Does anybody have any experience or input with this ?
I thought that having any type of locker in the rear would help in climbing hills on icy roads where I am in traffic and cant just step out and lock my hubs to put it in 4X4. I ve had this happen before and been stopped at an uphill intersection that has a patch of ice over the road, when the light turns green your just crawling up the hill <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> spinning one rear tire getting nowhere.
Theresa the Toyota Terror-89 Toyota P/U (3.0L SR5, 5sp swapped in from auto, 3"B.L., 32X11.5X15 MT/R, 2.5" stainless magnaflow catback exhaust, leaky floor with cold draft @feet, FUBAR comptron now in glovebox)
Re: Got any Aussie Locker install tips? [Re: 10_35lookoutbelow] #742437 08/25/06 06:00 PM
Buck Offline OP
I took 3 days to do mine. Someone experienced with diff's. probably could easily do it in one day, I'm sure I could have done it in a day and a half. First day all I did was drain the diff., jack up the truck and take the tires off, and the subsequent two days I only worked 4-6 hours each day on it.
84 Ext. Cab Pickup.
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.008s) Memory: 0.6374 MB (Peak: 0.7628 MB) Data Comp: Off Server Time: 2026-11-14 19:18:38 UTC
