Re: 1989YJ 4.2L Engine Swap to a 91 Cherokee 4.0L HO
[Re: josephelk]
#742877
08/09/06 08:52 AM
I think the condition of the two engines and drivetrains would be the deciding factor for me. I'd do a Bona Fide compression and leakdown test on both engines and after considering mileage oil pressure and vehicle histories, decide which one to use. I would even consider using both engines and building a stroker (putting the 4.2 crank and rods in the 4.0 block). I also recommend the site CSP posted for more info. All you need to know is in the archives so you don't even have to post there (not that there's anything wrong with that!) if you are good at searching. Good luck. <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: JeePete]
#742878
08/10/06 04:12 AM
I think the condition of the two engines and drivetrains would be the deciding factor for me. I'd do a Bona Fide compression and leakdown test on both engines and after considering mileage oil pressure and vehicle histories, decide which one to use. I would even consider using both engines and building a stroker (putting the 4.2 crank and rods in the 4.0 block). I also recommend the site CSP posted for more info. All you need to know is in the archives so you don't even have to post there (not that there's anything wrong with that!) if you are good at searching. Good luck. <img src="/forums/images/graemlins/cheers.gif" alt="" /> I agree i would also like to say another option is to do a head conversion(putting the 4.0 head and fuel inj on the 4.2).Which i did would depend on which block was better(less wear,not cracked and so on)
[Re: cuervo25]
#742879
08/10/06 04:47 AM
cuervo, did you read the original post?
#742880
08/11/06 01:32 AM
I found a gas tank out of a 91YJ (At the local junk yard) with the skid plat, sending unit and fuel lines for $185.00. I'm going to look at it this weekend. When I buy it IÆm going to do the Vent tube conversion before I put it in. They say I can gain 4-5 gallons of capacity by doing this?
Thanks
89 YJ, 3.5" Black Diamond Lift, 33" tires, 8000lb Warn, 4.0 91 XY engine swap.
[Re: josephelk]
#742881
08/11/06 08:26 AM
It's basically a 20 gal tank. I had a 91 YJ and it took 20 gals, I don't know if anyone had converted it or not, not me. <img src="/forums/images/graemlins/cheers.gif" alt="" />
#742882
08/26/06 02:14 AM
It terns out that the gas tank I purchased from the junk yard has a plastic try or small baffle in the bottom of it and it was loose inside. I took it out and was wondering if the sending unit will still work properly? Or will my gas gauge bounce or not be accurate.
Thanks
[Re: josephelk]
#742883
08/26/06 04:40 AM
Same thing happened on my tank. I just took it out and threw it in the garabge. So far so good...
#742884
08/26/06 05:09 AM
I had one of those too. I glued it back in place with GOOP sillycone glue... I do NOT know if it stayed or not. I never had problems with it after the glue. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6231 MB (Peak: 0.7050 MB) Data Comp: Off Server Time: 2026-06-10 01:23:22 UTCValid HTML 5 and Valid CSS
