Help! - DTC Codes - 2000 Toyota 4Runner #743061 08/07/06 04:35 PM
My check engine light on my 2000 Toyota 4Runner recently came on, and these were the codes that I found:
P0125 - Closed Loop Fuel Control Insufficient Coolant Temp
P1135 - Manufacturer Control. Fuel Air Metering
What would be the best way to attack these problems, and are they in any way related?
Furthermore, since the check engine light has been on, my car has not wanted to turnover at times, as well as stalled while stopped at stoplights.
Re: Help! - DTC Codes - 2000 Toyota 4Runner #743062 08/07/06 09:56 PM
Dandeman Offline
Toyota Moderator
Welcome to the 4x4wire forums... I'm sure you'll find lots of info and folks here that share your interest in Toyotas...
Yes the 1135 and 0125 codes are related...
The 1135 code indicates the heater circuit in your front O2 sensor is no longer working and therefore the O2 sensor has failed.
The wording of the 0125 DTC error description is somewhat of a red herring, but correct... What it means in your case, is that after the engine has warmed up and should be in closed loop mode, the computer is not seeing a valid the O2 sensor signal..
Other than checking to make sure the wiring is intact to the front O2 sensor, you need to replace the front O2 sensor... Make sure the dealer confirms your vehicle is California spec and gives you the proper O2 sensor.. The 1135 (vs the 0135 error discussed in the article below) code indicates your vehicle is a California spec vehicle.
Replace the O2 sensor and make sure it's no longer setting any codes.. then I'd recommend you clean the Mass Air Flow sensor as mentioned in the article below.. There's a link showing you the procedure...
Read this article first, and then this article on cleaning the MAF and other items you should check.
Re: Help! - DTC Codes - 2000 Toyota 4Runner [Re: Dandeman] #743063 08/07/06 10:44 PM
Thank you. That explanation was extremely helpful.
Re: Help! - DTC Codes - 2000 Toyota 4Runner [Re: Dandeman] #743064 05/27/07 12:19 AM
Dbryan22 Offline
Can you get to the O2 sensor wire through the dash? I just installed a new radio and keep getting that code (the vcs off/vcs trac/check engine) all of a sudden.
2001 SR5 4Runner 4x4
PHP: 7.4.33 Page Time: 2.454s Queries: 15 (0.004s) Memory: 0.5945 MB (Peak: 0.6536 MB) Data Comp: Off Server Time: 2026-06-10 08:38:03 UTC
